How long should I expect stock shocks to last with...
How long should I expect stock shocks to last if I went ahead and bought neuspeed race springs? 2.0 f 1.75 r...
really want to drop my car but don't have money for shocks + springs.. should I just go with the sports?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geminiGSR »</TD></TR><TR><TD CLASS="quote">How long should I expect stock shocks to last if I went ahead and bought neuspeed race springs? 2.0 f 1.75 r...
really want to drop my car but don't have money for shocks + springs.. should I just go with the sports?</TD></TR></TABLE> My stock shocks have lasted about 20,000 miles w/ progress springs. (200f, 320 r spring rates and 2.25 drop all around). Now it's definitely time for new shocks, but my oems held up for quite a while.
i have coil-over sleeves 200f/100r spring rates...i had them slammed at lowering 3 inches for a couple months, then just 2 inches lowered all around, for over 1.5 years and 18,000 miles. They're still good, i just got aftermarket shocks just cause stock shocks and aftermarket springs are bad combos
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nd8ch »</TD></TR><TR><TD CLASS="quote">i have coil-over sleeves 200f/100r spring rates...i had them slammed at lowering 3 inches for a couple months, then just 2 inches lowered all around, for over 1.5 years and 18,000 miles. They're still good, i just got aftermarket shocks just cause stock shocks and aftermarket springs are bad combos</TD></TR></TABLE>
200f/100r really isn't stiffer than stock. Neuspeed race, on the other hand, are VERY stiff springs. I wouldn't pair them up with stock shocks for any amount of time. Regardless of whether or not they blow, they can't handle the increased spring rate, and your ride is going to suck. Bad. Hold out a little longer until you can afford some shocks, IMO.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuraholic »</TD></TR><TR><TD CLASS="quote">
Regardless of whether or not they blow, they can't handle the increased spring rate, and your ride is going to suck. Bad. Hold out a little longer until you can afford some shocks, IMO.</TD></TR></TABLE>
just lowering the car already reduces the dampening potential of your stock shocks
depends on your driving, and road conditions, if u can slow down for everylil bump then stocks are gonna last a wail, if u're sick of tires rubbing the finder, then get some Shocks....
It also depends on the condition of the shocks currently so it's hard to say. But changing shocks and springs can be a big job especially if the bolts on your car haven't been loosened before. Why do all the work twice when you get the money for shocks? Just save up.
Agent STFU
16
Feb 23, 2003 08:31 AM
