ZC guys need your help
Old Aug 18, 2003 | 06:45 PM
R6Boy69's Avatar
Default ZC guys need your help
Does a distributor from a D16A1 (88-89 teg) have the same plugs as the ZC dizzy or does it have the same plugs as a 90-91 crx?
Old Aug 18, 2003 | 09:28 PM
blackZC (W)
Guest
Posts: n/a
Default Re: ZC guys need your help (crXBoy69)
yeah, you need the teg distributor. Si is lots different
Old Aug 19, 2003 | 07:23 AM
Slebidia's Avatar
88-91 DX also have the plugs you need.
Old Aug 19, 2003 | 07:58 AM
DJ_SaNdOz's Avatar
the Teg dizzy that you need comes w/ a square plug, the Si harness has a round plug. Yopu have 2 options...
1.) Change the plug on the harness side to the Teg plug so that the dizzy is plug & play
2.) Change the square Teg dizzy plug to a round plug everytime you need a new dizzy
I am doing option 2 right now b/c I didn't have teh Teg plug that I needed, it can become a PITA if your dizzy needs to be replaced frequently like mine (4 dizzy's in 2 months) but either way works just fine.
Modified by DJ_SaNdOz at 11:44 AM 8/19/2003
Old Aug 19, 2003 | 08:35 AM
therealciviczc's Avatar
88-89 is square plug, and I vote for converting the car to meet the dist if that is the dillemma. If there is one thing you want to be able to do to a ZC with ease, it's switch the distributor... eventually you'll be doing it.
Old Aug 19, 2003 | 09:56 AM
R6Boy69's Avatar
Default Re: ZC guys need your help (DJ_SaNdOz)
thanks guys... I was actually converting a wiring harness back from a zc so I can use it with my obd0 type R swap. I figured it all out. thanks again.
KevinEF7
Dec 24, 2012 12:34 PM
801ef
May 30, 2008 09:03 AM
crxzcracer
Sep 7, 2004 01:42 AM
rafimos
Feb 5, 2004 09:32 PM
turbo sol
Apr 28, 2003 11:08 AM
