skunk2 and koni yellows
does anybody have some info on putting skunk2 sleeves on koni yellow shocks? the rear sleeves sit in the perch, but the fronts have the grooved perch for springs to position on, so the sleeves dont sit correctly.
I guess I should answer this as I have 3 cars set up this way. You will need the special adaptor rings from either Koni or Skunk2 to use the shocks properly. These sit on the C-clip and then the sleeve rests on them. DO NOT use the standard stamped steel perches. Assembly will require modest effort to get the O-rings properly positioned. Other than that it is very straight forward. Cut the bumpstops in half and do not reuse the dust shields. The folks at Koni, NA in Hebron, KY are very helpful BTW.
gsrvong
Suspension & Brakes
May 1, 2012 09:11 PM
