Those who use Hondata, is fpr necessary?
Old Aug 18, 2003 | 06:04 PM
Rhetoric's Avatar
Default Those who use Hondata, is fpr necessary?
Just like the topic.
Do I need to get a fuel pressure regulator to tune with the hondata.
Planning to use the s100. Most posts I've read say that their tuner never
touched their fpr? Would I be okay without one?
Old Aug 18, 2003 | 06:44 PM
vtec.dc2's Avatar
Default Re: Those who use Hondata, is fpr necessary? (Rhetoric)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rhetoric &raquo;</TD></TR><TR><TD CLASS="quote">Just like the topic.
touched their fpr? Would I be okay without one?</TD></TR></TABLE>
do you need one? - no
is it good to have one? - yes. i've had my fuel pressure adjusted several times, you never know.. you might need to retune for more hp.. or just switch injectors.. wahtever the reason.. its good to have..
s100 is neat cause you don't have anything other than ecu.. but thats about it.. you might want to upgrade to datalogin or other features.. - get s200 - its worht the money.
and upgrade injectors while you're at it.. cause its not worth running hondata if your stock injectors can handle the whp..
Old Aug 18, 2003 | 07:43 PM
Rory Breaker's Avatar
No, you do not need an FPR.
Old Aug 18, 2003 | 09:36 PM
chameleon's Avatar
Default Re: Those who use Hondata, is fpr necessary? (newgsrdriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsrdriver &raquo;</TD></TR><TR><TD CLASS="quote">No, you do not need an FPR.</TD></TR></TABLE>
i have a S100B and no fpr, everything is done from that lil laptop when they tune.
Old Aug 18, 2003 | 10:40 PM
bojangs's Avatar
New User
Default Re: Those who use Hondata, is fpr necessary? (chameleon)
why would you need to adjust fuel pressure if you can control the injector pulsing with a hondata?
the adjustable fpr will be a waste of money.. unless of course you're buying it because you like the way a cute little purple/blue/red fpr looks.. =P
Old Aug 18, 2003 | 11:13 PM
Rhetoric's Avatar
Default Re: Those who use Hondata, is fpr necessary? (bojangs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bojangs &raquo;</TD></TR><TR><TD CLASS="quote">why would you need to adjust fuel pressure if you can control the injector pulsing with a hondata?
the adjustable fpr will be a waste of money.. unless of course you're buying it because you like the way a cute little purple/blue/red fpr looks.. =P</TD></TR></TABLE>
Thanks guys,
saved me a good 50 bucks
Old Aug 18, 2003 | 11:40 PM
ill phil's Avatar
Good info to know... guess it will save me some money as well!
sivikvtec
Aug 25, 2006 10:17 AM
Slightlyimperfekt
Mar 15, 2006 03:42 PM
TurboTeG4
Dec 15, 2004 01:24 PM
nieva
Oct 8, 2003 06:45 PM
skrewdlude
Aug 6, 2002 12:56 PM
