Just got my alignment done, now car wanders..... (suspension gurus -help!)
Old Aug 18, 2003 | 11:30 AM
Black93DelSolSi's Avatar
Default Just got my alignment done, now car wanders..... (suspension gurus -help!)
I got a sheet with all my numbers... check 'em out. Some of the numbers seem to be out of spec... I watched the guy do my whole alignment and he explained everything he was doing, it was really cool, the guy seems like a totally straight up cool guy. He's a honda guy, even... so I want to believe that my alignment is just fine... but the car doesn't act like it.
1. I have a CRAZY amount of throttle steer now. when i'm shifting hard, i let up off the gas and the wheel jerks to the right.
2. The bitch wanders all over the place, it's pretty subtle but it's friggin annoying!!! When i'm on the freeway I hold the wheel in one place and my car kinda decides to drift back and forth just a little bit... the only thing to prevent this is constantly turning the wheel back and forth to correct for this.... The steering wheel feels "loose."
3. I also have a lot of bump steer, i had bump steer before but now it seems worse...
Honda: Civic del Sol : with VTEC : 1993
Front Left:
................................Actual.........Bef ore.........Specified Range
Camber.....................-0.1.............0.1.................-1.3....0.7
Caster.......................1.0..............1.0. .................0.2....2.2
Toe...........................0.03...........-2.62..............-0.08..0.08
SAI..........................10.9..............10. 7.............................
Included Angle...........10.8.............10.8............. ................
Turning Angle Difference..................................-7.50..-3.50
__________________________________________________
Front Right:
Camber.....................-0.1.............0.2................-1.3....0.7
Caster.......................1.5..............0.5. ................0.2....2.2
Toe...........................0.03...........-2.52.............-0.08..0.08
SAI..........................11.1..............10. 6............................
Included Angle...........11.0.............10.8............. ...............
Front
Cross Camber.............0.0.............0.0............ ...................
Cross Caster..............-0.5.............0.5...............................
Cross SAI..................-0.2.............0.1...............................
Total Toe....................0.06..........-5.15...............-0.16-0.16
Cross Turn Diff.............................................. ...................
__________________________________________________ _____
Rear Left:
Camber.....................-1.2.............-1.1...............-1.5.....0.5
Caster........................0.03............0.20 ..............0.04....0.16
Rear Right:
Camber.....................-1.5.............-1.6...............-1.5.....0.5
Caster........................0.04............0.01 ..............0.04....0.16
Rear
Cross Camber.............0.4..............0.5........... ......................
Total Toe.....................0.07............0.22...... .........0.08....0.32
Thrust Angle...............-0.01...........0.10............................... .
So are my numbers ok?
What can I do to make my car feel better??
Old Aug 18, 2003 | 11:34 AM
EG2 SiR's Avatar
Default Re: Just got my alignment done, now car wanders..... (Black93DelSolSi)
I know EXACTLY what your problem is.... I just fixed it on my del sol... After a 4-wheel alignment and new tires..... The inner bushing on one of your LCA's is torn to ****.... You can easily repair by picking up a new LCA!!! I got mine from an import auto dismantler for $50!!! I am SOOOOOOO happy that pull is gone!!!
Old Aug 18, 2003 | 12:00 PM
Evil_Wizard's Avatar
Default Re: Just got my alignment done, now car wanders..... (EG2 SiR)
Your rear camber is in SPEC but it is all the way maxed to one direction. They need to put shims in the rear and fix that camber and it will probably be a lot better.
Old Aug 18, 2003 | 12:20 PM
Carlo's Avatar
Default Re: Just got my alignment done, now car wanders..... (Evil_Wizard)
I don't know if this'll help at all but try checking your tire pressure...
Old Aug 18, 2003 | 12:21 PM
EG2 SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2 SiR &raquo;</TD></TR><TR><TD CLASS="quote">I know EXACTLY what your problem is.... I just fixed it on my del sol... After a 4-wheel alignment and new tires..... The inner bushing on one of your LCA's is torn to ****.... You can easily repair by picking up a new LCA!!! I got mine from an import auto dismantler for $50!!! I am SOOOOOOO happy that pull is gone!!! </TD></TR></TABLE>
I'll put money on my idea. ^
Old Aug 18, 2003 | 12:39 PM
K, I'll replace the lca's.
Do you guys think that a steering rack "spacer" would help with my bump steer? I've heard that these work..... I don't know crap about no spacer... do you guys?
Old Aug 18, 2003 | 03:02 PM
Bump for the spacer!!!
Old Aug 18, 2003 | 03:15 PM
EG2 SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black93DelSolSi &raquo;</TD></TR><TR><TD CLASS="quote">Bump for the spacer!!!</TD></TR></TABLE>
sorry I cannot help, I am not familiar
Old Aug 18, 2003 | 03:43 PM
all stock's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black93DelSolSi &raquo;</TD></TR><TR><TD CLASS="quote">K, I'll replace the lca's.
Do you guys think that a steering rack "spacer" would help with my bump steer? I've heard that these work..... I don't know crap about no spacer... do you guys?</TD></TR></TABLE>
well, how about you inspect them first before you replace them?
it could be from uneven tire wear, or needed rotation. for all we know, it could be the freeway tilt.
Old Aug 18, 2003 | 03:59 PM
neutron91's Avatar
this guy is most likely right... if your caster is excessive its most likely the lower control arm... and if it was the camber that was excessive it would probably be your strut or knucle that is bad... check the bushings before you replace them though... good luck
Old Aug 18, 2003 | 04:01 PM
EG2 SiR's Avatar
Default Re: Just got my alignment done, now car wanders..... (neutron89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neutron89 &raquo;</TD></TR><TR><TD CLASS="quote">
this guy is most likely right... if your caster is excessive its most likely the lower control arm... and if it was the camber that was excessive it would probably be your strut or knucle that is bad... check the bushings before you replace them though... good luck </TD></TR></TABLE>
Yeah, definately check before replacing, but I can almost guarantee it is an LCA bushing... Especially if it pulls when you accelearate... It will go straight when braking, but when you punch it, one wheel moves forward and out, causing it to steer another direction....
Old Aug 18, 2003 | 04:06 PM
neutron91's Avatar
looking at his numbers im thinking it will pull more to the left
Idiotboy
Nov 23, 2005 07:52 PM
The Hooligan
10
Sep 3, 2004 05:18 PM
Black93DelSolSi
Aug 18, 2003 05:04 PM
98slvrcx
Nov 30, 2002 11:36 PM
ncitrdude
May 15, 2002 12:37 PM
