PM6 rev number
Old Aug 18, 2003 | 09:39 AM
SJR's Avatar
SJR
Default PM6 rev number
Couldn't find it in the search...
I have been told that the 90-91 PM6 ECUs had slightly better programming than the 88-89s. They're all PM6s but I am wondering what the revision numbers are on each. The one I have is a
37820-PM6-L031. The guy I bought it from said it was out of a 91 CRX, but the data stamped on the side is 87.10.01 (October 1st 1987...)
help?
Old Aug 18, 2003 | 09:47 AM
89civicdx's Avatar
Default Re: PM6 rev number (SJR)
if it says 87 I doubt it will be a 90-91
SOME ecus say "89" but came in 90-91 civic si crx si
here is the code from a 91 crx si
37820-pm6-coo
But the only way to tell for sure is to open the cover and look for the 28pin prom chip. As only 90-91 si ecu's can be chipped 89's didn't have the 28pin chip.Its located in the bottom right corner (looking at the ecu with serial # on bottom)
Just for your info on the dyno it didn't matter as all the 89-91 ecu's I tried made the same #'s.
If you want better maps go with the 89 teg ecu...or get the si ecu chipped.
Old Aug 18, 2003 | 09:53 AM
SJR's Avatar
SJR
Default Re: PM6 rev number (89civicdx)
just popped the top off, and there is a 28-pin NEC chip in the bottom right corner. It is NOT socketed though... it is labelled IC4. Is that what you are taling about?
thanks
Old Aug 18, 2003 | 11:41 AM
89civicdx's Avatar
let me break out the crayons
Old Aug 18, 2003 | 12:17 PM
SJR's Avatar
SJR
thanks. Nice crayons. So I don't have the right year. I do want the option to chip it in the future, since that is allowed in IT by the SCCA these days. Hard to tell from an Ebay picture though.
thanks again.
CR91X
14
Jul 25, 2008 07:58 PM
MtnCRX
10
Feb 11, 2005 03:02 PM
sicivic
Feb 14, 2004 06:01 PM
wpgcivic
11
Jan 20, 2004 07:41 PM
Aphrodavid
Dec 17, 2002 07:20 PM
