G3 Teg with 215/40-17 tires !!!???
Old Aug 18, 2003 | 05:45 AM
JDubya's Avatar
Default G3 Teg with 215/40-17 tires !!!???
do you rub bad? or if i roll my fenders, will i be fine?
Old Aug 18, 2003 | 10:51 AM
roadrunner's Avatar
Default Re: G3 Teg with 215/40-17 tires !!!??? (ALL MOTOR LS)
I had no rubbing on Rota 17x7's using Dunlop W-10's. I can't remember the offset, but what I had did not rub.
Old Aug 18, 2003 | 02:12 PM
mugenracer's Avatar
My last 17" rims were 7.5" wide and 38 offset, i had slight problmes with rubbing when i had on 215/40 tyres but none when i changed to 7" wide rims and 205 tyres
Old Aug 18, 2003 | 05:54 PM
98coupe's Avatar
From: NOVA, but OC MD for the summers, 10th St., Tyson R.I.P, USA
Default Re: (mugenracer)
215 on 17 40mm offset sportlines agx. Slight rub on fender liner in front not noticeable
Old Aug 18, 2003 | 06:22 PM
riceball777's Avatar
i run on the inside of the fender a lil
but its bot bad at all
17" ssr integals
215/40/17 toyo fz4's
Old Aug 18, 2003 | 06:36 PM
svtec's Avatar
L D E S
Default Re: G3 Teg with 215/40-17 tires !!!??? (riceball777)
i rub with kuhmos on racing hart c2 evos. 95 gsr.
neuspeed sport drop. tokico illuminas.
Old Aug 18, 2003 | 07:07 PM
boostdd's Avatar
It won't be that bad, probably when you bust crazy U-turns
Integra21
Jun 23, 2005 09:18 PM
beaterman
Dec 27, 2003 07:20 PM
Vtecfool
Oct 20, 2003 04:51 AM
h22accordturbo
Oct 29, 2002 10:04 AM
White Dragon
Nov 14, 2001 12:34 PM
