Vtec oil pressure sensor has 2 wires on it, everything I read says one?
Old Aug 17, 2003 | 07:56 PM
hughesl's Avatar
Default Vtec oil pressure sensor has 2 wires on it, everything I read says one?
I have the knock sensor, O2, Vtec sel. wired up, but everything I read says the oil pressure should have one wire to go to the ecu. My sensor has two. Which pins should I wire them two? Or do I just wire one of the two. One wire is blue and the other black.
Thanks for the help.
Old Aug 17, 2003 | 08:03 PM
MADEINIRAQ's Avatar
Default Re: Vtec oil pressure sensor has 2 wires on it, everything I read says one? (hughesl)
la la la.... black is ground. blue is signal.. run the ground to the ground screw on the thermostat housing..
GOOD LUCK
wookie.
Old Aug 18, 2003 | 03:34 AM
hughesl's Avatar
Default Re: Vtec oil pressure sensor has 2 wires on it, everything I read says one? (madeiniraq)
Thanks a lot, this had me confused and everything I researched came up blank. Have a good one
Red_ED8
Nov 19, 2007 06:26 AM
PaChiLa Leader
Oct 9, 2005 12:38 PM
PaChiLa Leader
Oct 8, 2005 09:56 PM
