FS: 1992 TURBO Hatchback
Vehicle Description
Immaculate 1992 Honda Civic DX Hatchback
Engine:
D16Z (SOHC Vtec) Can Handle Up to 25PSI
Max Ran 18psi
RiverCityDragWay San Antonio,TX
¼ Mile 11.78 (18psi Full Slicks)
Mugen Valve Cover
JE Pistons (9:0:1 compresion)
Crower Rods
Port & Polished Head
5 Angle Valve Job
FERREA Titanium Valves & Springs
Block Guard
AEM Fuel Rail
AEM Fuel Pressure Regulator
B&M Fuel Gauge
RC550 Injectors
Fluidyne Radiator
Fal Fan (single)
Fireball HI-6DSR Ignition Complete System(wires,coil,cap)
NGK-R Spark Plugs
ACT 6 Puck Race Clutch(extreme plate)
Needs changed
Hayame Cat-back Exhaust
Carbon Fiber Dual Pod A pillar
F-Max Turbo Kit
Equipment:
T3/T4 Turbonetics Hybrid Turbocharger
TIAL External Wastegate
Spearco Intercooler
· Spearco Intercooler core with 99% charge-side efficiency comes standard
Greddy Type-S Bypass Valve (BOV)
· Completely discharges excess boost pressure to eliminate compressor surge (boost spikes)
Fuel Management:
2 Additional Fuel Injectors
· New Lucas fuel injectors capable of delivering fuel up to 175 additional horsepower
ERL MF2 Additional Injector Controller
· A fuel injector controller programmed to deliver a 3D fuel map, maintaining proper air fuel ratio
· Delivers fuel up to 2 bar or 30 psi of boost
AEM's Plug & Play Engine Management System (EMS) is the first of its kind and will forever change the way you look at fuel injection tuning! This user-programmable system plugs directly into a vehicle's factory ECU harness and requires no additionalwiring or hardware*Windows-based software (200, NT,98,95,ME) makes the task of copying, viewing and manipulating data as simple as a click of the mouse. User-defined templates are easily configuragle and enable tuners to establish "quick keys" to any pertinent information during the tuning process. The AEM EMS's infinitely adjustable software allows tuners to program virtually any combination of engine control, power adders and auxiliary devices, and accurately deliver proper amounts of fuel and correct ignition timing for ANY boost level or operating condition.
Key Features:
Direct replacement for factory ECU-No additional wiring or hardware necessary*
Runs on Windows-based software
Installs in minutes
Automatic fuel mapping
Simplified intuitive user menus
16/32 Hybrid high-speed processor
Base maps included
Ongoard datalogging
Sequential fuel injection
Interactive, user-friendly manual
Nitrous, boost and knkock control
Forced induction compatible*
Made in the USA
Exterior:
Car is from TX and has no rust. Month ago moved to MN
New Championship White Paint Job
VIS Carbon Fiber Hood (wastegate cracked it)
VIS Carbon Fiber Front Lip
VIS Carbon Fiber Duckbill Spoiler
Angle Eyes (HALO) Projector Headlights
JDM Corners
JDM Taillights
Interior:
RECARO Racing Front Seats & Brackets
Wraped & Stitched Rear Seats (TYPE-R)
Wraped & Stitched Door Panels (TYPE-R)
Momo Race Steering Wheel
Sony Xplod M800 w/Remote
Reverse Indi Glow Gauge Cluster
Focal Tweeters
Rear & Front Speakers(no amp)
Brakes:
Rear Disc Brake Conversion
Front and Rear Slotted Rotors
AEM Pads
Suspension:
TEIN Racing Spec TYPE FLEX Control Master
Full Length Adjustable
16 levels of Damping Force adjustability
Teflon Coating Rust Prevention
Includes Pillow Ball Upper Mount
Compatable with EDFC
EDFC (electronic damper force controler)
Change dampering forces from inside the car
3 Prodgrammable presets
Adjust Front and Rear Separately
Change from 16 levels of damping force to 32
¼ DIN, Back-Lit
Electronics:
Blitz Fuel Auto Turbo Timer DCII
S2000 Push Button Start
Greddy Protec-B Electronic Boost Control Unit
Greddy Remote Wireless Switching System (low psi now 7)(high psi 13)
Pivot Shift Light
TEIN EDFC
Apexi Boost Guage(in psi)
Apexi EX-T Temp
Power Door Kit
Basic Alarm System w/Fuel Cut off switch
Wheels:
17. Tenzo R
Proxie Z4 Tires
Vehicle Condition
This is a beautiful vehicle that is sure to get multiple looks. Professional built, very clean inside and out. Drives very well, no problems. Vehicle has been repainted in the past year and a half. Body of vehicle has approximately 130,000 miles on it, engine has approximately 3,000 miles on it after build. Timing belt & water pump was done at 3,000 miles. All Seals & Gaskets replaced during build as well.
The A/C was removed as power gain and weight reduction but can be put back in.
I have one too many cars and I need the money to open a shop. Please email with any questions. Arrangements can be made to see vehicle in person .
FOR PICTURES GO HERE
http://www.xbox-wired.com/~armyofone/ AND CLICK THE IMAGES THEY WILL ENLARGE
Item Specifics
1992 Honda Civic 3 Doors DX
Mileage: 3000 VIN: 2HGEH2367NH513664
Get the Vehicle History Report
Number of Cylinders: 4 Type of Title: Clear
Transmission: Manual Interior Color: Black
Warranty: None Exterior Color: White
Standard
MANUAL 4 CYLINDER 1.5 LITER
Optional
AM/FM RADIO CD POWER DOOR LOCKS
iTS ALSO ON EBAY.
http://cgi.ebay.com/ebaymotors...52566
ASKING FOR 10-15k make offers
email is gatekeeper@xbox-wired.com
Modified by GOTNOS at 4:52 AM 8/18/2003
Modified by GOTNOS at 4:55 AM 8/18/2003
StillenMaxSE99
Dec 16, 2005 06:31 AM
StillenMaxSE99
Oct 2, 2005 02:50 PM
StillenMaxSE99
Sep 10, 2005 02:41 PM
