best t3/t04 turbo kit
Old Aug 13, 2001 | 02:45 AM
redteg1's Avatar
Default best t3/t04 turbo kit
fmax....drag....revhard??
Old Aug 13, 2001 | 07:58 AM
92CivicSiR's Avatar
New User
Default Re: best t3/t04 turbo kit (redteg1)
I personally think that F-Max is the best kit. It comes with a complete BOLT-ON system. When you install the kit, you dont have to remove ANY factory components off of the car to fit it in there. The system also comes with the additional fuel to compensate for boost, and the ignition upgrade so you can run stock timing under boost. The only thing about this kit is that it is pricey. If it were up to me, I would buy that one, but that's just my opinion. I hope that this helps.
Old Aug 13, 2001 | 08:09 PM
4dGSR at work's Avatar
Default Re: best t3/t04 turbo kit (92CivicSiR)
i DO hear good things about f-max kits. they are pricey! but the msd btr costs money and the fuel management isnt the best solution but i hear it works very well. btw if ya go t3t4 get the"b" trim not the "e" for a b16 thats what i would do... lower spool time too!
Old Aug 13, 2001 | 09:25 PM
redteg1's Avatar
Default Re: best t3/t04 turbo kit (4dGSR at work)
this is going on a b18c1
Old Aug 13, 2001 | 10:38 PM
liam821's Avatar
25 Year Member
i personally think f-max makes the best kit also. I have a custom kit, but use alot of f-max parts...like the piping which is soo much better then the drag.
Only downside to f-max is the price...
liam
Old Aug 13, 2001 | 10:59 PM
BishopB18C1's Avatar
Default Re: best t3/t04 turbo kit (liam821)
I'm from SD, Cali.. and personally I would recommend RevHard all the way! My friends all have RevHard and they're cars ar running great with he stage 2 setups. One is an 95 Intera GSR and hes running low 13s. with a litte more things to add on his motor. he will be hitting 12s all day long.. plus hes a daily driver so i give him alot of respect for his setup on his car. Pretty much the one with the GSR and his homeboys are all running revhad and running really goodtimes for stock motors. when they build theyre cars they will for sure be representin hard. and will get noticed.. thatsjust my opinion though... good luck on picking your choice of a turbo.....
Old Aug 13, 2001 | 11:07 PM
SIK IN DA HED's Avatar
New User
Default Re: best t3/t04 turbo kit (BishopB18C1)
got me a DRAG3 kit! so of course... im going to put my 2 cents in.
daym... this question seems to get asked every week.
Old Aug 14, 2001 | 07:41 AM
newsense's Avatar
New User
Default Re: best t3/t04 turbo kit (dlplayboy)
i have a revhard as well as 2 of my homboys....havent timed mine but they both have
94 ls STOCK MOTOR W/FULL INTERIOR ON 22in slicks 9psi: 12.8@105
91 ls STOCK MOTOR gutted on 22in slicks 12psi:12.5@109
they back em up all day long....pretty impressive kit if you ask me...cant wait to see what i'll do
civickid13
Apr 25, 2005 08:41 AM
Ben_si
Dec 26, 2004 09:53 AM
vtekstorm
Jan 18, 2004 12:21 PM
riceburnah
Nov 19, 2002 12:22 PM
AllMotorITR
Dec 8, 2001 11:45 PM
