Car bogging down from dead stops.....
Old Aug 17, 2003 | 05:43 PM
crexer's Avatar
Default Car bogging down from dead stops.....
Today I degreased and washed my engine bay and later on in the afternoon I was at a stop light and starting from first gear it bogged down so bad and was barely sputtering along and then it finally regained power and second did the samething, then in 3rd and 4th gear when mashing the gas pedal all the way to the floor it bogs more. whats going on?
Old Aug 17, 2003 | 08:37 PM
fourthgenhatchB17's Avatar
Default Re: Car bogging down from dead stops..... (crexer)
Check the spark plug tubes for water.
Old Aug 17, 2003 | 11:23 PM
ElementMotor's Avatar
Default Re: Car bogging down from dead stops..... (fourthgenhatchB17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">Check the spark plug tubes for water.</TD></TR></TABLE>
exactly what happened to me once......i used an air compressor to blow out all the water that got into where the spark plugs are....
Old Aug 18, 2003 | 05:47 AM
blah13's Avatar
Default Re: Car bogging down from dead stops..... (EF8 ownz u)
Also did you cover your dizzy when you washed it? Maybe pop the cap off and make sure its all dry.
Old Aug 18, 2003 | 10:17 AM
Vinceg99's Avatar
Default Re: Car bogging down from dead stops..... (blah13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blah13 &raquo;</TD></TR><TR><TD CLASS="quote">Also did you cover your dizzy when you washed it? Maybe pop the cap off and make sure its all dry.</TD></TR></TABLE>
Yeah thats what I was thinking. With my 85 CRX everytime I went through this car wash that had the underbody flush after I pulled out it started bogging like crazy sometimes even stalling until it dried off.
Old Aug 19, 2003 | 08:02 PM
crexer's Avatar
Yep thats all it was; a little bit of moisture in the spark plug holes and the dizzy a little damp; next time i'll be a bit more careful
thanks
ek4ferrio
Jun 3, 2007 02:59 PM
Initial DA6
Feb 9, 2006 08:01 PM
Draggin99Si
21
May 29, 2005 10:07 AM
ChingonGSR
Jan 17, 2004 10:44 PM
RH-TEG
Jun 25, 2003 07:08 PM
