NEED HELP FAST!! which brake lines to use for a rear disc brake conversion
Old Aug 17, 2003 | 04:28 PM
AzntaggeR's Avatar
TSPeed Factory
Default NEED HELP FAST!! which brake lines to use for a rear disc brake conversion
i just got done taking the drum brakes off my del sol and noticed that the brake lines don't match with the other brake lines i got off the integra.
so what i'm wanting to know is if the brake lines from the integra will work on my del sol...or will i have to find the brake lines off of a del sol si/vtec?
i need a quick response, because i'm working on the rear suspension right now.
Old Aug 17, 2003 | 05:35 PM
boostsohfast's Avatar
Default Re: NEED HELP FAST!! which brake lines to use for a rear disc brake conversion (AzntaggeR)
I think the brake lines will work without any trouble but I'm not sure. When I did a rear disc swap on a 98 ex all that was needed was e-brake cables so I know you will need them.
Old Aug 17, 2003 | 05:46 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: NEED HELP FAST!! which brake lines to use for a rear disc brake conversion (boostsohfast)
uh oh! ran into a new problem. the drum brake lines are steel and i need to swap it with the rubber brake line from the integra, but i can't seem to find out to remove it. i see no bolts or nuts holding it on.
i mean removing the brake line from the integra where it goes from a steel line and mates into a rubber line right before it goes to the disc brakes.
Old Aug 17, 2003 | 05:49 PM
jdmeg9's Avatar
they have a little clip on the sidewall i think like the front
Old Aug 17, 2003 | 06:02 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: NEED HELP FAST!! which brake lines to use for a rear disc brake conversion (jdmeg9)
i don't think so..on the rear it looks like the mount is welded to the frame.
OptxEm1
Suspension & Brakes
Jul 23, 2012 07:03 AM
sohctodohc
Apr 15, 2006 01:06 AM
Civichatch2k
Jan 9, 2005 07:17 AM
Civichatch2k
Jan 8, 2005 10:22 PM
neoboi
Jul 7, 2003 07:57 AM
