HELP!!! car wont start after camshaft instalation
check your plug wires, make sure that they are in order 1-3-4-2. also check that the distributor is not 180 degrees off, give more details on what the engine is doing, is it cranking over?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2 SiR »</TD></TR><TR><TD CLASS="quote">timing, timing, timing...... Did you check? It is a good sign that you did not hear anyting collide!</TD></TR></TABLE>
How do you check the timing? Doesn't the motor have to be running thats when I have checked mine?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rice_n_me »</TD></TR><TR><TD CLASS="quote">check the timing belt...I know, everyone says they did it right, but check it anyways...sometimes they magically jump teeth when you arent looking....did you adjust your valves too???</TD></TR></TABLE>
Yes we did adjust the valves
Deathwish
May 9, 2005 09:45 PM
The OEMobile
Aug 17, 2003 05:05 PM
