Piston Ring Gap
Old Aug 17, 2003 | 02:17 PM
Chuji's Avatar
Default Piston Ring Gap
I have a B18B bored out .20" over and im putting CP pistons in. The overbore piston rings that came with the pistons are out of spec but under the service limit. The top ring is .55mm. The factory spec calls for .20-.35mm with a service limit of .60mm. The second ring is alot better and very close to spec. Will this motor have blowby, will it burn oil? What should I do? I was about to put it in but im worried.
Old Aug 17, 2003 | 03:15 PM
RyanEJ8's Avatar
Default Re: Piston Ring Gap (Chuji)
You may loose a little compression too, I would just buy new rings.
Old Aug 17, 2003 | 03:22 PM
aeolus's Avatar
Default Re: Piston Ring Gap (RyanCivic2000)
if your using cp pistons,you should be using the spec. they gave you with the rings,not the factory ones
Old Aug 17, 2003 | 06:07 PM
Chuji's Avatar
Default Re: Piston Ring Gap (aeolus)
they gave me no specs or instructions with the pistons/rings.
hondachris1994
Dec 29, 2008 07:59 AM
Speedz
Nov 15, 2006 10:04 AM
ZzZCivicZzZ
Mar 15, 2006 07:24 AM
siis2fast
Jun 7, 2005 03:52 AM
B19CivicHB
Jun 19, 2003 04:15 PM
