consuming oil bigtime on a rebuilt b16a2
Old Aug 17, 2003 | 10:32 AM
sinatra's Avatar
Default consuming oil bigtime on a rebuilt b16a2
I recently had my engine rebuilt. I had the rings done, the rod bearings done and the head completely redone, springs, retainers, valves, guides, seats. Every now and then my car puffs blue smoke. Yes I know the boxed answer...rings. I am being told that my cat can be causing this problem also because it is melted and creating so much backpressure that the oil is being pushed into the combustion chamber. I am going through approx 4 quarts of oil a week in a car that consumed about 1 quart every 5000 miles originally. Should I be laying into my friend and expecting him to redo my rings? Could this all be caused by the melted cat? I would really like to know what is up here. I did a compression check and it went 1-4 195 200 200 215. So do a leakdown next? I really need to get this thing running well before clases start up because i won't have much time to work on it or have it be in the shop for days. Thanx guys.
David
Old Aug 17, 2003 | 11:15 AM
sinatra's Avatar
Default Re: consuming oil bigtime on a rebuilt b16a2 (sinatra)
anyone?
Old Aug 17, 2003 | 11:53 AM
jcda6's Avatar
It could be a number of variables....alot of times, it can be the valve seals. You didn't mention if the valve seals were replaced. The seals generally comes with the upper gasket kit.
-Jeff C.
Old Aug 17, 2003 | 12:27 PM
91tegrals's Avatar
damn i thought my car burned a lot of oil but damn 4qts well i would do a leakdown if you have already done a compression test and its all cool so maybe valve seals...
Old Aug 17, 2003 | 05:04 PM
sinatra's Avatar
I believe the seals were done when the seats were done. I will check though. Leakdown will be done in the morrow.
G3teg96
14
Aug 11, 2011 10:23 AM
orioncivic
Oct 10, 2008 02:00 PM
Hardedge
24
Oct 6, 2007 09:42 PM
crxhybrid85
Apr 18, 2005 06:47 AM
user 98292739
Feb 21, 2005 12:01 PM
