B16 head question
Old Aug 17, 2003 | 10:09 AM
thehatchninja's Avatar
Default B16 head question
hello to all, i think this is my first post in the all mota forum.
i have a JDM B18C (gsr) I was thinking about swapping on a B16 head in the future, but i was wondering what kind of gains i would get from it, and how much would i be talking about spending. Could i build it gradually, like buy the head and put in cams and valvetrain, maybe a diy port job (i'm poor). Any help or ideas would be great. tia. Also, would i need a diff ECU?
Old Aug 17, 2003 | 11:06 AM
roadawg's Avatar
Default Re: B16 head question (thehatchninja)
I doubt you would gain power with the b16 head............why not put a b18c5 head on there.
You could get a ITR head for 700$ or so.
Old Aug 17, 2003 | 11:56 AM
Default Re: B16 head question (SiRWanabe)
i'm pretty sure that the head is the same minus the mild porting, and cams.
Old Aug 17, 2003 | 12:08 PM
crxste's Avatar
The c5 head is essentially the B16a head with some mild porting.
Old Aug 17, 2003 | 12:15 PM
erbinone's Avatar
Default Re: B16 head question (crxste)
I heard better flow w/ a B16 head? I'm in the same position.
Old Aug 17, 2003 | 01:26 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: B16 head question (erbinone)
Keep the GSR head. Don't waste your money.
Old Aug 17, 2003 | 01:57 PM
Beave0101's Avatar
save your money, a port job on the gsr head will yield more more power than a b16 or itr head. People spend hundreds of dollars getting their PR3 castings welded like the pent-roof design that you have.
the downside to your intake flow is the gsr manifold, which also has potential, but is def. the downside to the head..(in stock form)
Old Aug 17, 2003 | 03:09 PM
11sHatcH22's Avatar
you should really get the b16 head. im sure you can get alot more power from it. so yes YOU SHOULD GET IT!
Old Aug 18, 2003 | 10:48 PM
OEMJDM's Avatar
Default Re: (11sHatcH22)
i say u get the Type R head, there was a guy in here that could get them for around $1200 BRAND NEW! with cams and everything inside the head new. if your interested PM me
Will
Old Aug 18, 2003 | 10:50 PM
ArinX's Avatar
U wouldnt gain ud lose .. compression that is
Old Aug 19, 2003 | 04:46 AM
kamakazesir2's Avatar
i would go for the b16a head cuz it flows better. same as itr 'cept cams and valvetrain. basically no huge difference.
Old Aug 19, 2003 | 05:25 AM
Default Re: (kamakazesir2)
or should i just get a SK2 mani and some cams.....or would an R head be cheaper??
Old Aug 19, 2003 | 05:59 AM
b19coupe's Avatar
Default Re: (thehatchninja)
For the money you would spend getting an "R" head, you could get the Skunk2 IM, cams, and valve train. Going to a B16 or Type R head, you are giving away compression, which is like giving away power.
Old Aug 20, 2003 | 07:12 PM
Default Re: (b19coupe)
how much would i spend on cams and valvetrain?
Old Aug 20, 2003 | 07:18 PM
b19coupe's Avatar
Skunk cams are going for aroun $650. Valvesprings about $280. Titanium retainers-$160. Total about $1100. You might be able to get a package deal even cheaper.
Old Aug 21, 2003 | 06:48 AM
f@sth@tch89's Avatar
GSR head...get the skunk2 IM.....Lemme know the dyno results...i have a b16 w/ a gsr head....trying to get it up and running....Hopefully I will be upgrading to the S2 IM soon.
Old Aug 21, 2003 | 06:15 PM
jeremy.'s Avatar
i'm using a b16 head on a gsr block...if you bold the b16 head right on the block you are going to lose some compression points and you are better off using a p28. go with what others say and just save yourself the hassle of switching heads and build your head, unless you plan on selling you gsr head
bullet647
Apr 17, 2007 02:47 PM
4175017
Sep 14, 2006 07:26 AM
hialeahzbg
16
Aug 1, 2006 10:57 PM
0bLiViOuS
Jun 17, 2005 01:10 PM
Spectrum24x
Feb 10, 2005 06:50 PM
