are toda cams loud?
Old Aug 17, 2003 | 02:07 AM
jessevtec's Avatar
Default are toda cams loud?
just want to know if my car is going to sound louder with my spec b's? will it sound loud in the top end like a race car?
Old Aug 17, 2003 | 02:37 AM
J2turbo21's Avatar
Default Re: are toda cams loud? (jessevtec)
From what i have read it is louder at idle do to the bigger lobes.
Old Aug 17, 2003 | 07:49 AM
T I F O S I's Avatar
they seem to be quite loud, but the only car ive seen with toda b's had no exhaust at the track so that could affect my judgement
Old Aug 17, 2003 | 08:08 AM
91integraLSVTEC's Avatar
Default Re: are toda cams loud? (goldeknug)
no there not that loud, u wont hear the difference but u'll feel the difference
Old Aug 17, 2003 | 09:42 AM
rodimus's Avatar
Default Re: are toda cams loud? (91integraLSVTEC)
not to be an *** but....
who really cares?
Old Aug 17, 2003 | 10:15 AM
realfasthonda's Avatar
Default Re: are toda cams loud? (EVOL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVOL &raquo;</TD></TR><TR><TD CLASS="quote">not to be an *** but....
who really cares?
i was thinkin the same thing to be honnest
Old Aug 17, 2003 | 11:15 AM
chris@allmotor.net's Avatar
Default Re: are toda cams loud? (realfasthonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realfasthonda &raquo;</TD></TR><TR><TD CLASS="quote">
i was thinkin the same thing to be honnest</TD></TR></TABLE>
Old Aug 17, 2003 | 11:21 AM
blbvtec's Avatar
Default Re: are toda cams loud? (chris@allmotor.net)
Old Aug 17, 2003 | 12:33 PM
jessevtec's Avatar
damn sorry for asking a simple question
Old Aug 17, 2003 | 12:52 PM
StinkyTofu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jessevtec &raquo;</TD></TR><TR><TD CLASS="quote">damn sorry for asking a simple question </TD></TR></TABLE>
Don't get so mad bro. I had toda cams in my car and yes, they are louder. When warming up the car, it clacks like crazy. It sounds really bad, like your car is gonna blow up or something. But after that, it sounds pretty stock. Some people don't like the idle chracterisitcs of the toda cams, but i personally love them.
Old Aug 17, 2003 | 01:06 PM
rodimus's Avatar
Default Re: are toda cams loud? (StinkyTofu)
i would just think that if you were worried about sound...
your first concerns were dealing with the intake sound (i.e. aem cai)
or exhaust sounds.
Old Aug 18, 2003 | 03:08 PM
guymosiris's Avatar
who really cares?
Actually, I'd like to know the same thing. I'm about to purchase a set, but wouldn't want to get pulled over for my car being so loud again, and have to deal with a smog referee in California again. I know what you're thinking..."then don't get em".
Old Aug 18, 2003 | 03:11 PM
EF_LSVtec's Avatar
Default Re: are toda cams loud? (guymosiris)
It is a lot louder than my old CTR's but only when on Vtec. Idle and below Vtec is just like stock...Keeps me from gunning it more than i should...
Old Aug 18, 2003 | 09:44 PM
AllmotorJunkie's Avatar
mine idles fine. I can't really hear it but I can F E E L it.
Old Aug 19, 2003 | 03:10 AM
J2turbo21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by guymosiris &raquo;</TD></TR><TR><TD CLASS="quote">
Actually, I'd like to know the same thing. I'm about to purchase a set, but wouldn't want to get pulled over for my car being so loud again, and have to deal with a smog referee in California again. I know what you're thinking..."then don't get em". </TD></TR></TABLE>
I dont think there gonna be so loud you will get pulled over hehe
Old Aug 19, 2003 | 06:12 AM
b19coupe's Avatar
My Civic is louder with the Toda's. I have a CAI, and when VTEC kicks in it roars. The car also smokes the tires in first gear, no matter what RPM it is at when the throttle is nailed, and that is kind of loud.
Old Aug 19, 2003 | 06:44 AM
len's Avatar
len
Yes they are going to be slightly louder than stock due to the increased induction of air. (Volume dependent on current intake and/or exhaust.)
In fact, any camshaft is going to be louder, per se, if they are of a different grind than OEM that allows more air to move inside the combustion chamber.
Old Aug 19, 2003 | 07:09 AM
Ink00's Avatar
Exhaust or no exhaust the Toda's are going to scream when they hit VTEC. But its well worth it!
Old Aug 19, 2003 | 08:08 AM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jessevtec &raquo;</TD></TR><TR><TD CLASS="quote">just want to know if my car is going to sound louder with my spec b's? will it sound loud in the top end like a race car? </TD></TR></TABLE>
i assume you mean loud transition from primary lobe to secondary lobe, if so then no, the spec B/C/D cams don't produce as loud a note as CTR/ITR/spec A cams due, all because of the big cam specs.
Funny i actually knew what you meant, cause you'd be surprised how many customers ask that, and i guess it means a lot to them when they hear VTEC ???
Greg
Old Aug 19, 2003 | 07:25 PM
NSX Bob's Avatar
New User
Default Re: (Ink00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ink00 &raquo;</TD></TR><TR><TD CLASS="quote">Exhaust or no exhaust the Toda's are going to scream when they hit VTEC. But its well worth it! </TD></TR></TABLE>
What are you basing this on, because it really isn't true. The x-over doesn't "sound" nearly as drastic as stock ITR cams.
Old Aug 19, 2003 | 08:08 PM
Josh717's Avatar
i think he meant when going into lift the car will pull harder
Old Aug 19, 2003 | 11:22 PM
Jaesung's Avatar
clacker noise is what i have with a messed up cat. mine idles at 1500 right now so there is definitely a problem with something. my engine light came on. didn't check the codes....
I am thinking about going with a toda valve train and the killer spec c cams in the future.
Old Aug 20, 2003 | 04:34 PM
NSX Bob's Avatar
New User
Default Re: are toda cams loud? (Jaesung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaesung &raquo;</TD></TR><TR><TD CLASS="quote">
I am thinking about going with a toda valve train and the killer spec c cams in the future. </TD></TR></TABLE>
Killer cams are one type of cam. Spec c's are another. Prepare to spend $ with either.
Old Aug 20, 2003 | 05:12 PM
len's Avatar
len
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaesung &raquo;</TD></TR><TR><TD CLASS="quote"> I am thinking about going with a toda valve train and the killer spec c cams in the future. </TD></TR></TABLE>
Bob, I think he's planning to run Killer Intakes and Spec C exhaust cams.
Old Aug 21, 2003 | 10:29 AM
NSX Bob's Avatar
New User
Default Re: are toda cams loud? (len)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len &raquo;</TD></TR><TR><TD CLASS="quote">
Bob, I think he's planning to run Killer Intakes and Spec C exhaust cams. </TD></TR></TABLE>
Lol, maybe that wouldn't be such a bad idea for your set-up, Len. Be an innovator, be original. Let us know how it goes, then try c's on the intake and killers on the exhaust side. Please post dyno graphs a.s.a.p.
