will polyurethane sway bar bushing cause stiffen a ride??
I
to Smooch Pickle
to Smooch PickleJoined: Jun 2003
but not.. in daily driving right?? like going straight line?? cause im tired of my car being bouncy.. actually changing all my polyurethane bushings back to stock.
bouncy? and you think that changing back to mushier bushings is going to help? Bounciness is generally caused by either your shocks being worn out or crappy rubber thats so soft it doesnt dampen correctly. Just for the sway bar bushings you probably shouldnt notice a difference.
sure you dont have apc coilovers on ur stock shocks...and now maybe you blew ur shocks causing this bouncy ride? I have all poly bushings..I dont bounce.
No, not stiffer, they transmit more vibrations from the road to the chassis. Harsher may be a better term. So would 'more responsive' and twitchy.
Bounciness and stiffness would be symptoms of to high a spring rate, or the dampers(shocks) to stiff.
Cheers,
Roy
Cheers,
Roy
Donavan Meyers
Nov 5, 2018 01:46 PM
Digitalis
May 21, 2015 09:15 PM
ChaseIntegra
19
Nov 29, 2004 12:16 PM
