Engine wiring harness compatability Q's
Old Aug 16, 2003 | 08:42 PM
MikeySpec's Avatar
Default Engine wiring harness compatability Q's
Hey everyone.Im buying a 89 crx dx that had a b16 swap.The guy sold that b16 to someone with the car's wiring harness attached.I was given a harness but its for a 88-91 Si and i know that doesnt plug in.Can i use one from a STD Civic?How about a CRX HF?Since he already wired for mpfi....is there going to be anything im going to have to extra?Any insight would be great.Thanks in advance...
Mikey
Old Aug 16, 2003 | 09:03 PM
bossman032's Avatar
Default Re: Engine wiring harness compatability Q's (CivicMikey)
u will need to convert to MPFI on ur dx then run vtec wires the swap is quite simple.
Old Aug 16, 2003 | 10:10 PM
b0pIT's Avatar
are you running the stock engine with DPFI? if so get a STD or DX engine harness but you will also have to change a few wires under the dash. two for dist and 2 for injectors. Bassically do the opposite of this http://www.geocities.com/c_rexboy/mpfi.html .
Old Aug 17, 2003 | 04:56 AM
Blown90hatcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicMikey &raquo;</TD></TR><TR><TD CLASS="quote">.I was given a harness but its for a 88-91 Si Mikey</TD></TR></TABLE>
88-91 harnesses are not all the same.
Old Aug 17, 2003 | 06:14 AM
MikeySpec's Avatar
Default Re: Engine wiring harness compatability Q's (Blown90hatcH)
Understood.Just wondering if an HF harness would work and if STD civic is the same as a dx harness.Any answers?Thanks...
Mikey
Old Aug 17, 2003 | 07:07 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
Dude, that is tricky.
Your best bet is to find an 89 DX harness and rewire the MPFI and VTEC part.
The harnesses between 88-89 and 90-91 are different.
I would not even try to guess if the Civic harness would be a plug in in your CRX.
Considering that you have to modify the harness that goes to the ECU in your car, you need to see what they did to modify it. You need to know how they ran the wires for the distributor (blue green and blue yellow) and also how they ran the wires for the two extra injectors. then you know how to modify the DX harness to make it work.
Old Aug 17, 2003 | 07:14 PM
MikeySpec's Avatar
Default Re: Engine wiring harness compatability Q's (Spaceballs the lunch box)
Thanks dude.I hate putting stuff together that was pre-done....i always come accross probs like this.
Mikey
Old Aug 17, 2003 | 09:56 PM
fourthgenhatchB17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spaceballs the lunch box &raquo;</TD></TR><TR><TD CLASS="quote">The harnesses between 88-89 and 90-91 are different.</TD></TR></TABLE>
Whats the difference? So you are sayin, for example, a 91 civic SI engine harness is different from a 88 civic SI engine harness?
I know the underdash part is different...
Old Aug 18, 2003 | 08:17 AM
No Big Whoop
Default Re: Engine wiring harness compatability Q's (fourthgenhatchB17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">
I know the underdash part is different...</TD></TR></TABLE>
yes they are.
One difference you notice right away, is the plug at the driver side.
The 88 si uses a rectangular plug while the 90-91 Si uses a round plug with two extra wires. there are more differences.
Old Aug 18, 2003 | 01:53 PM
yes they are.
The 88 si uses a rectangular plug while the 90-91 Si uses a round plug with two extra wires. there are more differences.</TD></TR></TABLE>
I will have to check that one out...never knew that. Its the plug thats by the resistor box?
Old Aug 19, 2003 | 07:51 AM
No Big Whoop
yes, the amber color one, not the green plug, that is the same.
CRseXy
Jun 27, 2005 04:17 AM
crxh22project
29
Jan 15, 2005 11:25 PM
NVMYSi
Nov 4, 2004 02:07 PM
CRseXxy
Jul 22, 2004 08:07 PM
capbyrd
Dec 16, 2003 03:45 AM
