will this ebay header fit a '96 gsr?
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stolenhubcabs »</TD></TR><TR><TD CLASS="quote"> http://cgi.ebay.com/ebaymotors...86775
the guy makes it a little unclear, just wondering</TD></TR></TABLE>
i just seen that header today. confused me too.
its a b seris header and all b seris headers will fit on all b seris heads
where the colector meats the cat is where it might have to be modified by a muffler shop
has anyone ever used this header, i was thinking of getting it but hes got alot of - comments on ebay, none about the header tho so who knows. ide like some feedback abefore i get it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 »</TD></TR><TR><TD CLASS="quote">its a b seris header and all b seris headers will fit on all b seris heads
where the colector meats the cat is where it might have to be modified by a muffler shop</TD></TR></TABLE>
This is not entirely true. B18's are a bit taller than b16's. A stock b16 exhaust manifold will not clear a b18c, and a number of aftermarket headers developed specifically for a b16 will not clear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5spdIntegra »</TD></TR><TR><TD CLASS="quote">My guess is that it's a piece of ****.</TD></TR></TABLE>
i 2nd that. you probably be better off with a DC header.
Depending on how much you can score it for, I would say its worth a shot. For under $200, youre pretty much going to be getting similar or worse craftsmanship, unless you buy used.
And DC's are the pinnacle of mass produced awfully crafted headers...unless you get a DC JDM, stay away from them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamTooQuick »</TD></TR><TR><TD CLASS="quote">Well its on a GSR motor in the pic so id say yes
....</TD></TR></TABLE>
i'm talking about the connection to the cat
....</TD></TR></TABLE>i'm talking about the connection to the cat
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gabe_ »</TD></TR><TR><TD CLASS="quote">
This is not entirely true. B18's are a bit taller than b16's. A stock b16 exhaust manifold will not clear a b18c, and a number of aftermarket headers developed specifically for a b16 will not clear.</TD></TR></TABLE>
Did you read what he said? he said all b series will bolt to head but may require mods to fit elswhere
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellaboi »</TD></TR><TR><TD CLASS="quote">
Did you read what he said? he said all b series will bolt to head but may require mods to fit elswhere</TD></TR></TABLE>
Did you read what he said? He did not say "other places" he specifically said:
A header not clearing the oil pan/bottom of the block is not a header/cat/exhaust needing to be modified to meet each other. The only way you would be able to make a header specifically designed for a b16 fit a b18 would be to add some length to each of the primaries, which would not be cost effective at all.
Modified by Gabe_ at 1:31 AM 8/18/2003
