ac killing my idle
when i turn on my ac the idel goes to crap
when the ac is on it will bring the idle to about 400rpm or lower and the car shakes like crazy. it sometimes even stalls the car. i tryed to adjust the idle so that its higher. i set the idel so that its about 1,000 rpm thinking that this will bring the idel up when the ac is on. but when i turon the ac the same thing happens. when the ac is on the idel drops really low.
what is the cause of this problem and how can i fix it.
i dont *think* there is a way to fix this unless your alternator is crapping out which would drop the voltage and make your car struggle or get a stronger alternator...i ahve this problem too but it doesnt drop that low. My idle will drop a little then bounce back up...its kinda like when u turn on your lights and the idle drops and bounces back up...only thing i can really suggest is tighten up the throttle cable and raise your idle...HTH and hope u get this fixed!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pr0jektdc2 »</TD></TR><TR><TD CLASS="quote">i dont *think* there is a way to fix this unless your alternator is crapping out which would drop the voltage and make your car struggle or get a stronger alternator...i ahve this problem too but it doesnt drop that low. My idle will drop a little then bounce back up...its kinda like when u turn on your lights and the idle drops and bounces back up...only thing i can really suggest is tighten up the throttle cable and raise your idle...HTH and hope u get this fixed!</TD></TR></TABLE>
i tryed to raise the idle
i raised the idle to above 1000 rpm and when u tur on the ac it still drops the idle like crazy
when the ac is on the idle does really really low to the point of almost stalling the car. the ideal stays low and doesent even bounch back up
can anyone pla help
what is the cause of this problem and how do i fix it
can anyone pla help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 »</TD></TR><TR><TD CLASS="quote">come on anyone???</TD></TR></TABLE>
There is a circuit that is supposed to compensate for the drag of the A/C do you have the helms for your car? Or the ETM for your car?
They should have flow charts for diagnosing that problem.
My '91 LS almost stalls when I turn the A/C on as well, but the idle does come up a few seconds after that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brian_TII »</TD></TR><TR><TD CLASS="quote">Idle air control valve? This is what is used to raise the idle when the A/C kicks on...</TD></TR></TABLE>
I have to re-check my helms. I always thought it was the ELD.
The Electric Load Detector, that raised the idle when some electric device
was used. IE the sunroof , rear defogger, headlights, A/C.
i have the same problem, except my car just shakes a little then but doesnt stall.
when you turn on the a/c do you have it on when the car first cuts on? b/c it seems to work a little better when i let the car warm up a little, then cut it on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brian_TII »</TD></TR><TR><TD CLASS="quote">Idle air control valve? This is what is used to raise the idle when the A/C kicks on...</TD></TR></TABLE>Yes. You can check that out, & clean it with throttlebody cleaner...
The ECM uses that to hold the idle steady when the AC clutch engages. Also when the alternator loads up with fans, wipers, 800w amplifiers, etc...
ek9mugen
23
Apr 10, 2004 10:32 PM
