piston question
Old Aug 16, 2003 | 02:30 PM
gregsr's Avatar
Default piston question
does anyone no any company that makes a 12:1 compression piston or higher for a b17a, and where can i purchase it at
Old Aug 16, 2003 | 02:35 PM
advanracing62's Avatar
Default Re: piston question (gregsr)
Endyn, JE, Arias, etc... just a std. bore 81mm piston. You could even use PCT, PR3, etc.
Old Aug 16, 2003 | 02:50 PM
gregsr's Avatar
Default Re: piston question (advanracing62)
tried using pct's, the rod is to big to connect to the piston, it also doesn't yield 12:1, I also tried Arias 12:1 pistons but it seems that their concept of standard bore is not so standard, as the piston was to large to fit into the cylinders, where can I find endyn pistons or the super duper wisecos,
Old Aug 16, 2003 | 04:18 PM
DOHC SOLDIER's Avatar
why don't you go 1.8? so much easier, and better
Old Aug 16, 2003 | 08:17 PM
97lsvtec's Avatar
talk to brad at rlz. he can get you any piston you want.
Old Aug 17, 2003 | 01:49 PM
owen_the_soyboy's Avatar
Default Re: piston question (97lsvtec)
http://www.importbuilders.com
ZCHondaCRX91
Engine Machining & Assembly
Feb 12, 2019 02:43 AM
JJDub
May 31, 2017 07:30 AM
2 0 3
May 6, 2006 04:23 PM
siis2fast
Jun 7, 2005 03:52 AM
b20ek
Jun 6, 2003 06:14 AM
