90-91 to 92-95 dizzy swap question
Old Aug 16, 2003 | 01:43 PM
streetdreams420's Avatar
Default 90-91 to 92-95 dizzy swap question
went to scrap yard today for 90-91 dizzy but none there. but there was a couple of 92-95 civics there and I was wondering if I can swap a dizzy off them onto a 90 si " I checked the wires and they all match up" can anyone help any info would be great
Old Aug 16, 2003 | 03:07 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: 90-91 to 92-95 dizzy swap question (streetdreams420)
Nope, don't even bother to rewire it.
The OBD0 ECU you have is not compatible with the OBD1 distributor.
Short of you opening the OBD1 distributor and replacing the sensors inside, the OBD1 just will not work.
It has to do with the number of pulses per revolution on the magnetic pick up of the sensors. the OBD0 uses fewer than the OBD1.
Old Aug 16, 2003 | 04:25 PM
Default Re: 90-91 to 92-95 dizzy swap question (Spaceballs the lunch box)
alright bro thanks for the help just having alot of truble finding a si dizzy, u were saying somthing about changing the sensors how hard would this be ?? I don't have the 92-95 dizzy yet so don't know
Old Aug 16, 2003 | 04:51 PM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetdreams420 &raquo;</TD></TR><TR><TD CLASS="quote">alright bro thanks for the help just having alot of truble finding a si dizzy, u were saying somthing about changing the sensors how hard would this be ?? I don't have the 92-95 dizzy yet so don't know</TD></TR></TABLE>
Don't quote me cause I'm certainly not positive about it, you'll need further
confirmation. The internal sensors do fire at a different pulse rate. So, the OBD1 dizzy and the OBD0 dizzys cannot be swapped or made to be compatible, but maybe you could put the OBD0 guts into an OBD1 dizzy housing. That is the part I'm not sure about. Post and ask. HTH
Jmar9289
14
Jan 13, 2011 10:25 AM
Seto-Initial-B
Feb 14, 2008 08:06 AM
JDM RHD eg6
Mar 26, 2005 09:02 PM
b16powwer
17
Jul 4, 2004 02:02 PM
