WHat is a safe rev range on my setup
Old Aug 16, 2003 | 01:43 PM
InspiredRacer's Avatar
Default WHat is a safe rev range on my setup
I have a SIR_G engine starting with 10.6cr
Head is ported and polished with .030 deck
Ported intake manifold with secondary butterfly tray removed.
DC 4-2-1 to apex-i worldsport exhaust.
Cam gears, fpr, intake
I will be running a chipped ecu and was wondering how high I can go with this or If i get some top end pieces?
Old Aug 16, 2003 | 02:06 PM
jeremyEG's Avatar
Default Re: WHat is a safe rev range on my setup (InspiredRacer)
i take my stock internal c1 to about 8400. my rev limmit is at 8600 and ive only hit it once. that was only because i thought it was at 8800 but found out its not
8400 is about as high as i see a need to go.
Old Aug 17, 2003 | 09:53 PM
Default Re: WHat is a safe rev range on my setup (jeremyEG)
I'm thinking 8700. Anyone have a problem there?
Old Aug 17, 2003 | 10:15 PM
HONDADNA's Avatar
did you upgrade your valve springs and rods or rod bolt if using stock rods?
Old Aug 17, 2003 | 10:37 PM
Default Re: WHat is a safe rev range on my setup (HONDADNA)
Nope
I'm asking how high is safe on stock engine. I don't plan to run at 9k, but I would like to know if mid to high 8's are acceptable
Old Aug 17, 2003 | 10:50 PM
mmuller's Avatar
Mad Scientist
with would you wanna rev that high with stock cams?there is no need to rev any higher than stock.
Old Aug 17, 2003 | 11:09 PM
Default Re: WHat is a safe rev range on my setup (mmuller)
Let me explain
Valvetrain and cams cost too much for the gains. I'd rather invest in a turbo.
I'm going to do my head and intake manifold and have fun with my car. My ecu is getting a chip and I wanted to know what others have been running theres to. Only dyno charts tell me where to shift a car. Not stock fuel-cut
Old Aug 17, 2003 | 11:15 PM
mmuller's Avatar
Mad Scientist
if you really wanna do it.....
my b16 i rev to 8400 only at the track, because of ls tranny
my ls/vtec is going to rev to 8300 with r cams
BoostModeCivic
Oct 7, 2013 10:04 AM
littlegreenb18
13
May 26, 2006 01:08 PM
lv6l
27
Sep 13, 2005 11:27 AM
SohcVtecCrix
Nov 19, 2002 01:12 PM
E46M3CB
Feb 28, 2002 11:09 AM
