92 Honda Accord DX sedan
Old Aug 16, 2003 | 12:05 PM
Oilman's Avatar
Default 92 Honda Accord DX sedan
Trying to help a friend: Engine cranks, won't fire. 'Suspect fuel delivery problem.
'Can't hear fuel pump running in tank.
'Can't find a fuel pump fuse in either box, neither a relay ?! Where are they??
Both ECU fuses are OK.
Your help is appreciated.
Thanks.
Old Aug 16, 2003 | 01:35 PM
StimpyBoy's Avatar
Default Re: 92 Honda Accord DX sedan (Oilman)
You're probably going to want the main relay. It's far, far up under the dash. Do a search to see if the symptoms match.
http://autorepair.about.com/li...1.htm
Old Aug 16, 2003 | 04:38 PM
TomSlick's Avatar
Agree with Stimp...fuel pump is powered thru main relay. You're due to replace anyway.
Old Aug 16, 2003 | 04:44 PM
ChaosUnbound's Avatar
Old Aug 16, 2003 | 09:22 PM
RUBZERK's Avatar
Default Re: 92 Honda Accord DX sedan (ChaosUnbound)
its a good thing i introduced that relay site to you guys
by the way i sell relays
Old Aug 17, 2003 | 06:31 PM
b18c4door's Avatar
Do these things go out often or something and should they be replaced periodically?
I have a 91 wagon and am not sure if I should do this before it goes out on me !!??!!
Thanks!
Old Aug 17, 2003 | 07:08 PM
StimpyBoy's Avatar
Default Re: (b18c4door)
Don't bother replacing it until you have problems with it. This shouldn't be a maintenance item, it's stupid they're this defective.
Symptoms of a bad main relay:
1) Car cranks but won't start
2) Car starts, but immediately dies after
Both of these are aggravated by hot weather, and will tend to go away after a couple minutes. You can listen for the fuel pump priming at the gas tank, if it doesn't that's likely a main relay problem.
Until this happens, leave the ******* wagon alone
Old Aug 18, 2003 | 08:38 PM
b18c4door's Avatar
Default Re: (StimpyBoy)
oh yeah, this wagon rawks...soon to have a new suspension setup...pro-kit, tokicos and ST bars...booyah !
civic91sief
Nov 5, 2009 10:59 PM
88YellowRexSi
May 31, 2006 06:56 PM
YodajdmEK4
Oct 3, 2005 09:24 AM
dabigrog
Jul 12, 2004 06:37 PM
accord1987dx
Apr 12, 2004 10:14 PM
