WilWood Brake Kit and 16" LE37t (43 Offset)
Will this combination work? This is for my 99 Civic.
It's this kit: http://www.wilwood.org/ds375.pdf
and I need 14.2 inches vertically for the the 4 piston calipers
Thanks,
Cruzer
Thanks,
Cruzer
The Wilwoods fit fine behind my 16x7, +42mm TE37's on my DA Integra. Caliper face clearance was abundant, but radial clearance was a little tight. I had to move the tape wheel weights in so they wouldn't rub on the caliper. The tire still balanced though.
I don't thibk you'll have a problem.
