will 255 inline pump work?
need to knoe if a 255 walbro pump from a 95 civic si will work for a 88 crx si, but need to knoe what i have to do to get access to the crx fuel pump ot switch if there compatiable?
A 95 Civic Intank pump will work, but you do have to do some modifications. I'm using a 94-98 teggy/civic pump (PN 12-917 walbro) and I had to buy a strainer for my stock tank and change the wiring from the stock screw on clips to a clip on style (you'll see when you pull it all apart). I've also heard it's a good idea to upgrade all the wiring as well. Just remember that you MUST have the pump sitting in EXACTLY the same way as the stock pump. Oh, you'll probably have to zap-strap the pump to the holder too.
Hallzie
Jan 21, 2015 04:42 PM
