FS: Import Tuner Cover car 02 WRX (56k good luck)
$33k obo
O2 Subaru WRX..
Silver
VIN will be published to a MOD uppon request.
The car has 24,5xx miles on the clock but the current motor has about 19,xxx on it. ( motor blew with 5000 on it and was replaced by irvine subaru.)
This WRX appeared on the JAN/03 cover of Import tuner. The car has been to SEMA once and to NOPI nationals once, With many more to come. Now to the goodies..
EXTERIOR
http://www.kaminari.com/products/02WRX.htm
Kaminari Front Lip with One Piece CF Splitter
Kaminari Sideskirts with CF inserts
Kaminari Rear Skirt
Kaminari Reverse Cowl CF hood
Kaminari "Race Wing" with CF Blade
STI Headlights
STI Rain Guards
STI CF SideMarkers
STI Emblems
Subaru Fog Light Covers
INTERIOR
Sparco Torino Seats (blue/Grey)
Sparco RED Harnesses
Sparco Steering Wheel
Sparco Shift ****
STI Aluminum Door sill plates
Suspension/wheels/brakes
18" Gunmetal VOLK Gram Light 57 Pro's
Toyo RA-1 235/40/18 (i believe)
STI version 7 takeoffs (struts/springs)
STI strut tower bar
Energy Suspension Uretane Bushings
ST sway bars
The Brake Man "tornado" wavy high performance brake system(complete)
Steel Braided brake lines
Electronics/system
Turbo XS UTEC engine managment
BLITZ Sbc ID Electronic boost controller
BLITZ Turbo Timer
BLITZ Power Meter
BLITZ DC series Gauges (Boost,oil temp, oil pressure)
VUZ in car camera system
G-NET in car computer (PC)
Blaupunkt Head unit
Rosen 6.5" TV screen
Rosen 6 disc DVD changer
XTANT 2 10" SUBS
MTX 5.25" AND 6.25" Speakers
XTANT LE titanium a4004 amp
XTANT 3001 LE titanium AMP
Engine/Drivetrain
TurboXS IHI VF34 Turbo
TurboXS Catless Up pipe
TurboXS Catless Downpipe
BLITZ FMIC
Walbro 250lpm Fuel Pump
STI 550cc Injectors
Injen Intake
BLITZ NUR spec Exhaust system
KAAZ Close Ratio Synchromesh Gear Set
KAAZ Front LSD
EXCEDY Dual Plate Clutch w/ EXCEDY flywheel
STI Tranny mount
I think that is all. If i think of more I will update. The Camera system and the speakers are NOT installed. Thank you for your time...
Forgot to mention..... the last time it was on the dyno like a year ago, it made 320 @ 20psi
Chris
Import Beat
Modified by The P.I.M.P at 1:30 AM 8/16/2003
O2 Subaru WRX..
Silver
EXTERIOR
Kaminari Rear Skirt
STI Headlights
STI Rain Guards
STI CF SideMarkers
STI Emblems
INTERIOR
Sparco Shift ****
STI strut tower bar
ST sway bars
Electronics/system
BLITZ Turbo Timer
BLITZ Power Meter
Blaupunkt Head unit
XTANT 2 10" SUBS
Engine/Drivetrain
BLITZ FMIC
STI 550cc Injectors
Injen Intake
KAAZ Front LSD
STI Tranny mount
Chris
Import Beat
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Atheist »</TD></TR><TR><TD CLASS="quote">Wow, bump for the nice *** wrx</TD></TR></TABLE>
ditto
ditto
Thanx for the bumps.... yea the car is in the wrong place but i figured its worth a try..As far as the kaaz gears go, we dont know yet, it wont be installed for another week or so.. were getting that,the LSD and the Cltuch put in, but its taking time cause the new synchro's and etc, are comming from japan thru rally spec in new jersey..
We have to do that because we chose to use the stock casing instead of the 96-97 sti tranny(which the tranny was made for)..If you want a gear set, lemme know i can get em cheap...
Chris
Import Beat
P.S. As most of h-t would say, this car would "OWN" an STI.
BTW, it still has a warranty
Chris
Import Beat
4LugR
Northern California (Sales)
16
Oct 19, 2007 03:01 AM
sleepycivix
Apr 24, 2003 04:25 PM
