1000 in./lbs. impact wrench enough to take off crank pulley?
Old Aug 15, 2003 | 01:44 PM
david90's Avatar
Default 1000 in./lbs. impact wrench enough to take off crank pulley?
Will a 1000 in./lbs. impact wrench enough to take off crank pulley? people told me 600 was enough but i'm not sure it is in ft/lbs or in/lbs. what is 100in/lbs converted to ft/lbs.
Old Aug 15, 2003 | 01:57 PM
fluxion's Avatar
amin n'rangwa edanea
Default Re: 1000 in./lbs. impact wrench enough to take off crank pulley? (david90)
divide by 12, it would be like 85 ft/lb
Old Aug 15, 2003 | 03:18 PM
Superorb's Avatar
dood, just use a breaker bar, and either use the tool for the crank pulley to hold it in place, or jam something into the teeth of the flywheel if u take the starter off, thats what i did
Old Aug 15, 2003 | 04:02 PM
david90's Avatar
That would be my last resort.
Old Aug 15, 2003 | 04:28 PM
AngryTR0LL's Avatar
Who rates a 1/2" impact in in/lbs? My cordless impact produces more torque than that...
Old Aug 15, 2003 | 04:35 PM
TypeSH's Avatar
Default Re: 1000 in./lbs. impact wrench enough to take off crank pulley? (AngryTR0LL)
my right arm produces more torque than that w/ a breaker bar.
there was a deal from homedepot like 2 weeks ago on a clearance husky one, like 250 ft/lb, not sure if its still available.
http://www.anandtech.com
goto the forums, then hot deals, and then search for impact.
Old Aug 16, 2003 | 12:11 AM
david90's Avatar
Default Re: 1000 in./lbs. impact wrench enough to take off crank pulley? (TypeSH)
200 is not enough I think. Dewalt rates their with in/lbs. Not sure why.
Old Aug 16, 2003 | 09:25 PM
kentucky accord's Avatar
i havent seen an airtool yet(3/4" impact included) that wants any part of an accord/prelude crank pulley bolt. civic/teg are cool all day long but the bigger accord/prelude bolts are tight.
best thing to do is get a breaker bar, floorjack handle for leverage, and the biggest pair of channel locks you can find. place the channel locks onto the crank pulley itself(outermost part) and let them rest against the axle or control arm or something else solid. the harder you pull to get the bolt free, the harder those channel locks bite and they will not slip.
dont jam screwdrivers into the crank pulley holes or anything else. i have seen crank pullies shatter from things like that.
Old Aug 16, 2003 | 10:04 PM
david90's Avatar
channel locks = pulley holder tool?
Old Aug 17, 2003 | 06:07 AM
Default Re: (david90)
channel locks are big adjustable pliers. you know, the kind that have multiple slots to make the "plier part" bigger or smaller. here is an example of what i have and use. and yes, they are called BigAzz channel locks and actually have "BigAzz" engraved on them.
http://www.channellock.com/acb..._ID=4
Old Aug 17, 2003 | 06:18 AM
GimpyAccord's Avatar
Default Re: (kentucky accord)
best tool, ever:
http://www.thetoolwarehouse.net/shop/TTW419.html
before i got this, big pipe on end of a 1/2" breaker bar i didnt care much about with assistant holding the flywheel teeth via prybar.
Old Aug 20, 2003 | 11:24 AM
david90's Avatar
I made my own pulley holder. I just buy a hex nut that fits into the pulley's hex groove and place a monkey wrench on the other ends of the hex nut. works good.
Old Aug 20, 2003 | 12:43 PM
TypeSH's Avatar
what size was the hex nut?
Old Aug 20, 2003 | 01:14 PM
david90's Avatar
50mm offset. Oh and i welded the 2 hex together
Old Aug 21, 2003 | 04:13 PM
94AccordCoupe's Avatar
Didn't you post about this awile ago? You still haven't gotten it off? People could argue about this all day but I really dont think its a good idea to subject the crankshaft to the repeated shock of a high power impact wrench. You can do it with a breaker bar and a pipe. And if needed get a torch and get the bolt hot. Also a larger friend always helps
Old Aug 21, 2003 | 07:26 PM
slickrc's Avatar
its this simple, i went throught the same thing, not know that u had to turn clock wise, like if u were tighting it
Old Aug 21, 2003 | 08:26 PM
TypeSH's Avatar
how much were the parts and where did you get them?
Old Jul 13, 2009 | 03:07 PM
vanny_david's Avatar
here's my cheapo method:
a flywheel
2 flywheel bolts
a breaker bar
and a friend of yours
get your friend hold the flywheel while you torque the crank pulley
Old Jul 13, 2009 | 05:43 PM
TouringAccord's Avatar
H-T Order of Merit
I'm not sure what you are trying to describe but in any case, how many people just have a flywheel laying around?
Old Jul 13, 2009 | 10:22 PM
porter351's Avatar
first get a torch, heat the bolt for about ten minutes. then get a imack socket, breaker bar, and a big *** bar on the end of the breaker bar. have a friend hold the brakes whille the car is in fifth gear and break that bitch loose. the hotter u get the bolt the better. has to be a impact socket or else u will crack the socket. works like a charm everytime
Old Jul 14, 2009 | 01:47 AM
GhostAccord's Avatar
Any one notice that this post is 6 years old. I love that people are using the search function but maybe we should start reading the dates on posts...lol
Oh just to ad some tech to my post. I used a crank pulley tool and a breaker bar to get my crank pulley off. Much easier than trying to use any kind of impact gun. It needs constant pressure to break the thread lock.
Old Jul 14, 2009 | 05:12 AM
H-T Order of Merit
no it doesn't. only need an impact socket if you are using an impact gun. maybe you are using inferior sockets?
I've used the same socket multiple times on crank pulley bolts and have yet to break a socket.
Old Jul 14, 2009 | 05:14 AM
H-T Order of Merit
haha, yep, that was the first thing I noticed.
x2, work great
Old Jul 14, 2009 | 08:02 AM
porter351's Avatar
i was saying if u heat the bolt up u need a impact socket, after u break three sockets u realize this. craftsman isnt that inferior to me. i know it aint snapon but whatever.
Old Jul 14, 2009 | 08:22 AM
lakerschamp2000's Avatar
snap on 500 ft torque would do the job
i got a dewalt cordless 300 ft barely take out the wheel's lugs
