94 Civic w/ Turbo Gsr
1994 Honda Civic Ex w/ 115,xxx miles
2dr coupe
No A/C or P/S
Can supply a/c parts just need smaller downpipe.
Engine
1994 Acura Integra Gsr w/ 86,000 miles
Drag Gen III Turbo kit w/ polished compressor 11,000 miles
Tial wastegate- open dump
HKS Blow Off
Stainless Oil Return
3” Downpipe and Full Exhaust Magna Flow Muffler-All Stainless
JG Engine Dynamics 64.5mm Throttle Body
Skunk2 Intake Manifold-Natural Finish
450cc Injectors
B&M Fuel Pressure Regulator
BBK 190lph Fuel Pump
MSD Sport Compact Ignition
MSD Blaster Coil
MSD Distributor Cap
Magnacore Wires
Engine Management
Hondata 2B W/ P72
Transmission
1994 Gsr w/ 86,000 miles
Action MD 6 Puck Clutch 8,000 miles
Phantom Grip LSD
B&M Short Shifter
Suspension
Ground Control Coil Overs
KYB AGX Shocks and Struts
Energy Suspension Urethane Bushings
Custom Urethane Engine Mounts- Jim Fab
Focuz Front Strut Bar
Integra Front Sway Bar
Wheel and Tires
Velox VX8-R Wheels
Ventus HR-II 205/55R16 4k miles
Will also include nitto dr's mounted on Acura wheels
Interior
Indiglow Gauges
Silver Gauge Bezel
Greddy Turbo Timer
Color Matched Interior Parts
Sound And Security
Pioneer DEH-8000R Cd-Player- A Few Buttons Missing But Works Fine
Precision Power PC-275 Amp
JL Audio 650-CS Components
JL Audio 650-CX Co axils
MTX 81000D Sub Amp
JL Audio 13W7 sub
JL Spec. Sub box
Stinger Deep Cycle Battery (Front)
Optima Deep Cycle Battery (Rear)
Silver 0ga. Battery Terminals and Connectors
0ga. Power and Ground Wire
Entire Car Dynamatted
Code Alarm 3100
Exterior
Xenon Body Kit
Cervini's Sniper Hood
Brakes
Brembo Cross Drilled and Slotted Rotors
Axxis Metal Master Pads
This is a non smokers car.
I bought this car with 60k from dealer. Original owner was a female had all services done at same dealer. I swapped in the Gsr at 70k, swap had 40k on it. Turbo installed at 104k on car 75k on engine. I had run 13.73@105 with on old slipping clutch. Has current Pa inspection. Oil changed every 3-3.5k. Rear window and pass. side window have new glass. There is a dent on the pass. side quater panel(pic enclosed) and normal wear. I have invested around 25k. Looking to get 11,000. Subtract 1,000 without stereo equipment. Will give vin to those interested. Any questions pm, email me at johnmay19@yahoo.com or call 610-656-6894.
Modified by johnmay19 at 3:58 AM 12/2/2003
2dr coupe
No A/C or P/S
Engine
HKS Blow Off
450cc Injectors
MSD Blaster Coil
MSD Distributor Cap
Magnacore Wires
Engine Management
Hondata 2B W/ P72
Transmission
Phantom Grip LSD
B&M Short Shifter
Suspension
Wheel and Tires
Velox VX8-R Wheels
Interior
Indiglow Gauges
Silver Gauge Bezel
Greddy Turbo Timer
Sound And Security
MTX 81000D Sub Amp
JL Audio 13W7 sub
JL Spec. Sub box
Code Alarm 3100
Exterior
Xenon Body Kit
Brakes
Here is the link:
http://f2.pg.photos.yahoo.com/...o.com/
Modified by johnmay19 at 2:14 AM 9/25/2003
I may partially part out. Such as shell then engine, turbo and management would need buyers for everything though. If any interest let me know.
RIP ILL: 26Jan1945-02Feb2017 -&- JLVK: 14Jun1925-13Dec2016
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnmay19 »</TD></TR><TR><TD CLASS="quote">I may partially part out. Such as shell then engine, turbo and management would need buyers for everything though. If any interest let me know.</TD></TR></TABLE>
if you're considering this, (i'm just curious...) how much would you want for the motor/tranny/turbo/hondata??
also, any internal work done on the motor??
how much boost are you running on regular basis?
I just had my 94 turbo civic stolen in Balt. 2 weeks ago and i'm still looking for another car. Yours looks pretty sweet. i'm definitly interested in the car as a whole. What's the lowest u could go without all the stereo equip?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnmay19 »</TD></TR><TR><TD CLASS="quote">Here is the link:
Modified by johnmay19 at 2:14 AM 9/25/2003</TD></TR></TABLE>
