Where to find Wire harness for H22?
Old Aug 14, 2003 | 08:43 PM
NVS_RSX's Avatar
Default Where to find Wire harness for H22?
My friend has the H22 installed in his Accord already but its not running right. The wire harness that came with the H22 is all messed up. I need to know where we can purchase some aftermarket wire harness or mostly the easy to get Used wire harness?
Im pretty sure we should check the junk yard first but I just want some info from where you guys get ur harness at.
Thanks!
Old Aug 14, 2003 | 09:11 PM
Accord94DX's Avatar
Default Re: Where to find Wire harness for H22? (NVS_RSX)
i have a spare wire harness to an F22b2 if you need it. pm me
Old Aug 15, 2003 | 06:10 AM
jakks20's Avatar
The easist way to do it is to use the Accord harness and just add the 4 wires that are needed (knock,vtec solenoid,vtec pressure, and IAB).
Old Aug 15, 2003 | 08:07 AM
grocerygetter's Avatar
just a question...if you are using a 5G ex accord wiring harness...what do you need to add?
Old Aug 15, 2003 | 12:12 PM
KTeller8's Avatar
Default Re: (grocerygetter)
1- you shouldnt be trying to use the h22 harness in your accord, it wont plug into the chassis
2- use your accord harness but just length the wires, as mentioned on every website that has any info on doing the simple swap
3- if your lx, you must run the 3 vtec wires to the ecu.. no biggie.. just run some wire right to that bad boy and go....
by the way i have an old h22 harness left over, if you still need it to pull off sensors cause you messed yours up, not knowing what your doing
Old Aug 15, 2003 | 09:34 PM
NVS_RSX's Avatar
thanks for the quick replies. I'll go check with my friend and see what he wants to do
Old Aug 18, 2003 | 07:03 PM
NVS_RSX's Avatar
Default Re: (NVS_RSX)
How much are you guys selling your H22 wire harness for. We are interested in getting one!
RSR_Mike
Jul 20, 2011 11:19 PM
omarisramo
Jul 3, 2008 05:17 AM
Team Highway
Sep 11, 2007 08:03 PM
FROSTDC2
Apr 7, 2006 08:26 PM
Bowlergi21
Aug 22, 2003 04:50 PM
