SDS users?
4F or whatever...the one with the included ignition is the only system that is worth it.
smog guys should not even know you have an aftermarket ecu other than no longer having a distirbutor. just get your car tuned relaly good then turn on closed loop and you should be fine.
as for the upcomming Smog Dyno in California i don't think any aftermarket ecu will work on a OBD2 car due to them plugging in that socket into the ECM reader or whatever.
delslowhonda
May 2, 2006 10:52 PM
