FS: ITR rear swaybar
Old Aug 14, 2003 | 06:53 PM
Vitt1's Avatar
Default FS: ITR rear swaybar
I added this in another FS post but can't change the title to reflect the sway bar, so I need a new post:
ITR Rear sway bar (BAR ONLY, No Endlinks, bushings, brackets, etc) $50 shipped--firm to 48 states.
Also have a 19mm Neuspeed if you want a more balanced 92-95 Civic. See sig below. thanks.
Modified by Vitt1 at 9:20 AM 8/15/2003
Old Aug 15, 2003 | 08:20 AM
Vitt1's Avatar
Default Re: FS: ITR rear swaybar (Vitt1)
TTT
Old Aug 15, 2003 | 08:34 AM
dohc-nyne's Avatar
22mm or 23 mm??
Old Aug 15, 2003 | 08:56 AM
Racerboy03's Avatar
Default Re: FS: ITR rear swaybar (dohc-nyne)
Im very interested, just out of curiousity, how much is it for new end links, and would I need ITR endlinks or can I use the ones from my Si? Also, is it 22mm?
Old Aug 15, 2003 | 09:57 AM
Vitt1's Avatar
Default Re: FS: ITR rear swaybar (Racerboy03)
It's the 22mm. If your car already has endlinks then I don't think you need new. I used my GSR's and it's the same as the ITR AFAIK. You will need the bushings a couple other things. Here is a list of what you need. (I think I saved this from a post on HT if not mistaken):
2.) 52315-ST7-Z01 swaybar bushing (2 needed)
3.) 52308-SS0-000 bushing bracket (2 needed)
4.) 52316-ST7-Z00 endlink bushing (2 needed)
5.) 52312-ST7-Z00 endlink bushing collar – this part can be reused from the stock swaybar
EDIT: You can use the ones from your car if they are new.
6.) 90175-ST7-Z00 bolt (2 needed)
7.) 94050-08080 flange nut (8mm) (2 needed)
You can get these parts from http://www.ahmotor.com, and ask them about the endlink as well. I think they'll tell you if you can use your Si.
Old Aug 15, 2003 | 10:04 AM
Vitt1's Avatar
One more thing. You should also buy a chassis reinforcement kit to prevent tear out. HT Member BSQ sells these.
Old Aug 15, 2003 | 10:30 AM
Thrillhouse's Avatar
you still have the bar? you have a pm
suprmods
Jul 27, 2007 08:38 PM
VSM_EK
Northwest (Sales)
Dec 9, 2006 10:31 AM
Integra21
Jan 13, 2004 06:25 PM
Hasboro
Oct 12, 2003 11:18 PM
