ITR vs. GSR cam lift & duration???
Old Aug 14, 2003 | 03:39 PM
fu*kfaceC1EH2's Avatar
Default ITR vs. GSR cam lift & duration???
The deal... 95 hatch with b18c1, have an opportunity to pick up some usdm R cams, and was wondering the numbers... between my stock gsr cams and itr cams, lift.. duration? and also, if i can get these cams for under 300, would that be a sufficiant upgrade, or should I save up for some different cams? I plan on tossing on a JRSC and I'm not looking for som insane stage 3's or anything. Later on if I learn the best cams for a supercharged B, ill sell these without a problem im sure. WHP comparisons from stock to itr in a gsr motor? thanks for whatever ya got.
-Danny
Old Aug 14, 2003 | 04:34 PM
Rocket's Avatar
Default Re: ITR vs. GSR cam lift & duration??? (fu*kface95hatch)
If they are in good condition it's a good buy.
Old Oct 5, 2003 | 06:37 PM
dabomb's Avatar
someone must have itr cams in a b18c1!!! come guys let us know the difference.
thanks
Old Oct 5, 2003 | 07:05 PM
juggernaut's Avatar
Default Re: ITR vs. GSR cam lift & duration??? (dabomb)
will let you know soon just ordered my usdm itr's and will get it tuned shortly after install.
Old Oct 5, 2003 | 11:24 PM
Default Re: ITR vs. GSR cam lift & duration??? (juggernaut)
i forgot i posted this, and still haven't found out!
Old Oct 5, 2003 | 11:25 PM
and another bump!
Old Oct 6, 2003 | 07:25 PM
jappower's Avatar
For exact specs on both, go to the crower cams website, they have all cam specs listed. As for personal experience, I have a 94 GSR. With bolt ons, best 1/4 et was 15.1@94mph. Rebuilt w/ 11.3 compression and 2000 usdm ITR cams, best et was 14.21@98mph. Now I have Skunk2 stage 1 cams(intake same as type-r,exhaust has a little more lift and duration) and Skunk2 p28 drag program ECU, best et 13.71@101mph. The ITR cams will make a lot more power than the GSR cams, especially w/ higher compression.
Old Oct 6, 2003 | 07:43 PM
GokuSSJ4's Avatar
Default Re: ITR vs. GSR cam lift & duration??? (jappower)
Integra GS-R
Int-274 dur. / 10.7mm lift
Exh-276 dur. / 9.6mm lift
Following Cams Measured at 1mm of lift:
Integra Type-R(Through 1999 Spec)
Int-240 dur. / 11.5mm lift
Exh-235 dur. / 10.5mm lift
Civic Type-R And Integra Type-R(Integra Type R 2000/01 Spec)
Int-243 dur. / 11.5mm lift
Old Oct 6, 2003 | 10:57 PM
Default Re: ITR vs. GSR cam lift & duration??? (Spoon1)
cool you guys, i appreciate it
JPerkMr954
Apr 5, 2011 07:13 AM
GSRintegra_Bob
Oct 10, 2005 09:49 AM
GoodFella
Feb 18, 2004 12:58 PM
IgniteTeg
Jun 30, 2002 11:57 PM
