Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
How To reset the Maintenance Required light for the 3.5RL
Old Aug 14, 2003 | 10:19 AM
Chris's Avatar
Default How To reset the Maintenance Required light for the 3.5RL
A member had asked me in IM and I cant remember who.
Turn ignition to (II) (dont start the car)
Set trip to (Trip A) or (Trip B) *will not work if outside temp is displayed (this was why we could not get it to work??)
HOLD SELECT and RESET at same time for more than 10 sec
Turn car off.
Just FYI for the archives.
Old Aug 15, 2005 | 04:16 PM
SoCalWrencher's Avatar
Default Re: How To reset the Maintenance Required light for the 3.5RL (Chris)
does this work on an 01 3.2TL?
Old Aug 15, 2005 | 04:20 PM
Kenso's Avatar
HT White Ops
Default Re: How To reset the Maintenance Required light for the 3.5RL (SoCalWrencher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCalWrencher &raquo;</TD></TR><TR><TD CLASS="quote">does this work on an 01 3.2TL?</TD></TR></TABLE>
Hold down select and reset buttons, then turn the key to the "on" position while holding the buttons. In about 10 seconds the light will go out and the system has been reset.
Old Oct 24, 2005 | 10:05 AM
98JDM_Type_R's Avatar
Default Re: How To reset the Maintenance Required light for the 3.5RL (Kenso)
great thread
Old Oct 25, 2005 | 10:20 AM
Redline96LX's Avatar
* B A N N E D *
Default Re: How To reset the Maintenance Required light for the 3.5RL (98JDM_Type_R)
where was this info a year ago when my dad needed it? Thanks a lot, my dad has a 03 TL right now that needs this, ima go try it.
Old Dec 10, 2005 | 06:44 PM
^^^^ back up for those who need it
Old Dec 10, 2005 | 07:52 PM
ITR 692's Avatar
just what i needed to know. thanks guys.
Old Feb 24, 2010 | 11:17 AM
turbahatch's Avatar
Turn car off.
WRONG!!!
The correct procedure would be to hold down both buttons BEFORE you ever put the key in the ignition than turn it to the (II) when the light turns off turn off the car and you are done!!!
Just clearing things up so u don't get as frustrated as I did following the wrong directions!!!
Old Feb 24, 2010 | 03:50 PM
slomofo's Avatar
GDD Member
Key in, key out, doesn't matter, just as long as the buttons are pressed when the ignition is turned off.
Old Feb 25, 2010 | 02:17 PM
YeuEmMaiMai's Avatar
for the 2ng gen CL and TL the reset procedure is the same press and hold reset and odo select buttons and turn the car on (do not start) continue to hold buttons 10 sec
Old Jan 31, 2012 | 10:22 AM
Matt Jordan's Avatar
I was due for the A1 service and for some reason the only thing that worked for me was selecting the oil life meter and holding the Sel/Reset button for 10 seconds. I use Amsoil so I will change it sometime this summer.
Pierre1088
Honda Civic (2006 - 2015)
Sep 5, 2008 04:36 PM
j-bird20
Dec 14, 2006 08:45 AM
Ek9_6
Honda S2000
Oct 2, 2006 11:17 AM
ImXposed
Aug 31, 2005 06:28 AM
SPOON_BeIgHtEeNsEe
Acura TL, RL & ZDX
Jan 29, 2004 03:47 PM
