My Dream Honda (56K, I have about 37 pictures of parts)
<FONT COLOR="red">This is what I want, if you don't like something, explain why!</FONT>
Disclaimer: I may be using your pictures or manufacturers pictures, but you post'em and I'm borrowing them.
If you want your name mentioned for your pic or whatever, IM me, I'll add it.
Chasis:
1999-00 GBP Civic HX Coupe
Engine:
-K20A Head
-K24 Bottom end
-Custom 11:1 comp pistons
-Forged rods
-Toda Headgasket
-blueprinted and balanced
-ACL bearings
-ARP bolts and studs
Drivetrain:
-K20A 6 speed w/LSD
-Toda Clutch and Flywheel kit
-Spoon Drain plugs
Shoes:
-SSR Competitions 16X7
-Yokohama Advan A032Rs 205/45/16
Cooling:
-Fluidyne Radiator
-Fal Slim fan
Suspension:
-Tein RA suspension
-SPC Front Chamber kit
-SPC Rear Chamber kit
-SPC Rear Toe kit
-SPC LCA's
-99-00 26mm SI front Sway
-Comptech Sway/Tie combo
-Carbing 3pt bar
-Benen rear upper strut brace
-Benen front lower tie bar
-Benen strong bar
-HASport motor mounts (still in production)
Brakes:
-Fastbrakes 11.75" 6 piston front brake kit
-Fastbrakes 96-00 Civic Drum to 11" Conversion kit w/drilled rotors
-1" master cylinder
-Drive brake cylinder brace
-Adjustable brake prop valve
-Motul 600 brake fluid
Intake:
-Individual Throttle bodies
-Toda Spec A cams and valve springs
-Hondata Gasket
Fuel:
-190lph fuel pump
ECU:
-Hondata Hack and Tune
Body:
-VIS FC hood
-Hood locks
-OEM Side markers
-JDMHondaparts CF Lip
-CTR Headlights
-CTR/SI Grill
-FAL back half
-4-point roll cage
-Sparco RevC seats
-Sparco steering wheel w/removable hub (285mm)
-Design Engineering, INC. Reflective tape for anything that need protection from heat
Exhaust:
-Toda header
-Custom 2.5inch exhaust w/21" straight through resonator, and straight through muffler with silencer option
-Catco high flow catalytic converter
Guage/cluster:
-Civic SI cluster
-DEFI Link-system guages (BF model)
Guage off
Guage on
Neat system huh!
Whaddya think?
Chasis:
Engine:
-K20A Head
-K24 Bottom end
-Forged rods
-Toda Headgasket
-ACL bearings
Drivetrain:
-K20A 6 speed w/LSD
-Spoon Drain plugs
Shoes:
Cooling:
-Fluidyne Radiator
-Fal Slim fan
Suspension:
-Tein RA suspension
-SPC Rear Toe kit
-SPC LCA's
-Carbing 3pt bar
-Benen strong bar
Brakes:
-1" master cylinder
Intake:
-Hondata Gasket
Fuel:
-190lph fuel pump
ECU:
Body:
-VIS FC hood
-Hood locks
-OEM Side markers
-CTR Headlights
-CTR/SI Grill
-FAL back half
-4-point roll cage
-Sparco RevC seats
Exhaust:
-Toda header
Guage/cluster:
-Civic SI cluster
Guage off
Guage on
Neat system huh!
Whaddya think?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo »</TD></TR><TR><TD CLASS="quote">how bored are you?
HAHA, gonna say the same thing
Edit- why the Yoko A032R's????? They're a good rain tire, but other tires will kill them on the dry track.....
</TD></TR></TABLE>HAHA, gonna say the same thing
3 days of boredom and re-consideration.....I must have changed my mind a hundred times LoL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b cruz »</TD></TR><TR><TD CLASS="quote">sounds good... what about the exhaust y0?</TD></TR></TABLE>
It's there
Was thinking Titanium, but.....well might go to that
</TD></TR></TABLE>3 days of boredom and re-consideration.....I must have changed my mind a hundred times LoL
It's there
ummm wow... dream car i would say so... im sure there are some more things that would be great like bushing kits etc... but overall i dont think there are too many things you can do to it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">
Edit- why the Yoko A032R's????? They're a good rain tire, but other tires will kill them on the dry track.....</TD></TR></TABLE>
Bling factor yO! Basically I like the tread pattern. And those are the street tires....If I could afford all of this, my track tires would be racing slicks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coptzer »</TD></TR><TR><TD CLASS="quote">ummm wow... dream car i would say so... im sure there are some more things that would be great like bushing kits etc... but overall i dont think there are too many things you can do to it</TD></TR></TABLE>
Was thinking about Progressives Spearical Bearing kit to replace the bushings.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Plan B »</TD></TR><TR><TD CLASS="quote">but will that really make you happy?</TD></TR></TABLE>
Nope, not till that sucker is AWD.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damge »</TD></TR><TR><TD CLASS="quote">Win the Lotto Now</TD></TR></TABLE>
Wanted to win it Saturday......a check for $45 mil, I'd pay Ryan, Ryan and Ryan (and a few others) to take a week off
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by navin »</TD></TR><TR><TD CLASS="quote">mc brace's are hype...</TD></TR></TABLE>
Line 1 of post:
<FONT SIZE="4">
Line 1 of post:
<FONT SIZE="4">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmtr y0! »</TD></TR><TR><TD CLASS="quote">you cant use that header on a 6th gen civic with a k20 can u???</TD></TR></TABLE>
Nope. On the K20's the intake is in front and exhaust in the back.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philip »</TD></TR><TR><TD CLASS="quote">how do you feed air to the 4 seperate throttle bodies?</TD></TR></TABLE>
They just suck in air right there at horns attached to them
No "Intake" or filter.
bwahahahahahHAHAHA!
Hey he really has put a lot of time into this...time not spending money on parts = time spent considering what parts to buy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade »</TD></TR><TR><TD CLASS="quote">
Work, what work?
Modified by RSZero1 at 12:25 PM 8/14/2003
</TD></TR></TABLE>bwahahahahahHAHAHA!
</TD></TR></TABLE>Work, what work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nikos »</TD></TR><TR><TD CLASS="quote">Nice imaginary hatch.
Since you did all this, how about a estimated total?
Off the top of my head, without the car I would say 20K</TD></TR></TABLE>
Yup. Around 20K + chasis, since I don't have that, then build time and dyno tuning,
It's a 50K car.
It's a 50K car.
You forgot one thing on your list....3 or 4 full time armed security goons to keep it from being stolen and stripped!
