170hp enough for 13's?
my car dyno at 170hp at south florida performance yesterday. do you think i can hit 13's with azenis? btw my integra weigh in around 2600 with me in it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g5r »</TD></TR><TR><TD CLASS="quote">my car dyno at 170hp at south florida performance yesterday. do you think i can hit 13's with azenis? btw my integra weigh in around 2600 with me in it.</TD></TR></TABLE>
if you can get a good 60' time, you'll be in the 14.5 range. it all depends on your driving skills! good luck! are you going to moroso on sonday? if i go i'll be in my friends light blue 96 ek, with a 00 si front end!
I think it's possible...Just for comparison, my old del sol dyno at 174 whp and 123 lbs of torque. The car weigh 2450 w/o me and 2600 with me in it. I ran 14.4 @ 96 mph on street tires. The 60' was 2.2. I think with a 1.9-2.0 60' on slick, it could have hit high 13's. Good luck and let us know if it does.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g5r »</TD></TR><TR><TD CLASS="quote">the best time i had was on azenis, 14.2@97.6, my 60' was 2.22. the car weigh in with me inside was around 2600.
p.s my base run was 161/117lb</TD></TR></TABLE>
What kinda torque now?
Modified by Boostfed at 9:42 PM 8/14/2003
i ran a 13.7 with my gsr hatch it just had open jdm header and short ram intake and advanced timing ? it weighted 2320 with me in it and my 60 ft were 2.1-2.2 on street tires ( 195 50 potenzas)
My 99 EK is 2590 with me in it....175whp......13.60-13.70's with a 2.08 60' on BFG drag radials. More often than not its the torque which people forget is a factor....170hp B16 and a 170hp B18C5 have different torque characteristics....so that is one factor also...I run a C5 so my 129ft lbs pulls a little harder than 110ftlbs
Its more than possible but you have to be a pretty decent driver to pull it off but is not impossible as some would think.
I'm thinking it is posible but will be tough. You will need a perfect run. I'm in a 98 ex coupe with a d16y8, cai and a 55 shot of no2. My best is a 14.89. Keep in mind the track was wet and I was on pos steelies with pos tires
I'm thinking I can pull a 14.6 on a dry track with my pos tires. I'm probley putting down about 148whp
i made 175HP with 195ftlbs torque with a LS and a 50 shot in my teg in my old set up ran a 14.1 with 14 x 6 inch slicks in vegas, it might be kinda hard to run 13s with the azeins..
I ran 13.7 this last weekend in my 99 si coupe weighing in at 2375 pounds... All I have in my car is B18C-R with AEM 3" CAI, and Apexi WS Exhaust. Depending on your driving skills I could see you running 13.999 at least if you really try at it...
Maybe with a CRX. But certainly not in a 2600 pounds Integra. You have to figure that a stock ITR puts out somewhere around 170WHP. And it only runs 14's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt »</TD></TR><TR><TD CLASS="quote">Maybe with a CRX. But certainly not in a 2600 pounds Integra. You have to figure that a stock ITR puts out somewhere around 170WHP. And it only runs 14's.</TD></TR></TABLE>
Active Aero ran a 13.70 on street tires with I/H/E.....its all about driving and traction.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SergEK »</TD></TR><TR><TD CLASS="quote">
Active Aero ran a 13.70 on street tires with I/H/E.....its all about driving and traction.....</TD></TR></TABLE>
and the best track in the world
MMP was the track he ran at, they stay open year around which allows us to lay down nice times during the winter(cold air). I am projecting 14.1's@98~99mph this winter for my passat(more mods since the time you see in the sig, much more) and hopefully I will have either a B18b turbo or B18C5(can't decided between boost or n/a yet) in the civic and will be able to lay down some nice times in the civic as well.
