Proper harness mounting ?
Old Aug 14, 2003 | 06:28 AM
White Dragon's Avatar
Default Proper harness mounting ?
Does anyone know where to find the proper way to mount a 5 or 6 point harness. For an example, I know that you do not want the shoulder straps to go strait to the floor behind the seat as it may cause spinal injury during a roll-over. I thought I saw somewhere where it showed the correct angle range for both the shoulder straps, and the sub belt.
Thanks.
Old Aug 14, 2003 | 06:33 AM
sgT's Avatar
sgT
Default Re: Proper harness mounting ? (White Dragon)
route the shoulder straps over the harness bar in the cage or mount them to the cage.
the lap belts should be mounted behind the seat
sub belt goes through the seat not over.
Old Aug 14, 2003 | 06:38 AM
.RJ's Avatar
.RJ
Default Re: Proper harness mounting ? (sgT)
http://www.teamsimpson.com/cat...o.asp
Old Aug 14, 2003 | 06:39 AM
Dropspeed's Avatar
From Sparco:
"It is strongly recommended that the shoulder harnesses are fitted as close to horizontal as possible. It is a must that the angle of the shoulder harness does not exceed 45 degrees in relation to the theoretical horizontal axis of the mounting points..................."
Mattj
Old Aug 14, 2003 | 08:31 AM
Default Re: Proper harness mounting ? (Dropspeed)
Thank you all for your help!
Old Aug 14, 2003 | 09:47 AM
Brett@SoloRacer.com's Avatar
Check the PDF file about 1/2 way down the page here, it has some helpful info...
http://www.soloracer.com/gforcecamlock.html
trevorjohn88ef
Jul 19, 2008 04:09 PM
buck02
Jan 2, 2007 03:28 PM
B33R
Mar 3, 2006 10:46 AM
6ghatch
Jan 26, 2003 11:29 AM
92SiB18C1
Sep 3, 2002 05:15 PM
