How much HP is Type R bottom end good for?
Old Aug 14, 2003 | 05:58 AM
blumeany's Avatar
Default How much HP is Type R bottom end good for?
I am planning on boosting my Type R. I am replacing the pistons with lower compression slugs and I am also going to go with some Crower connecting rods.
What I want to know is how much boost can I safely run without worrying about the sleeves cracking. I am also running a Hondata S200, and will be getting everything tuned.
Thanks in advance
Old Aug 14, 2003 | 06:02 AM
pissedoffsol's Avatar
25 Year Member
Default Re: How much HP is Type R bottom end good for? (blumeany)
tuned right you should be fine in the 300s, more if you want to push it
PM-Performance's Avatar
Theres someone on here making over 500whp on stock sleeves, not on a type r though, but b series have the same sleeves as far as i knowof.
Old Aug 14, 2003 | 06:03 AM
DaveF's Avatar
are you talking about the stock sleeves or aftermarket ones????
id say you could prolly reach around 500 to the wheels on a good tune. with the stock sleeves. who knows how long it would last though.
Old Aug 14, 2003 | 06:04 AM
DaveF's Avatar
Default Re: How much HP is Type R bottom end good for? (2.2Lcivic)
damn guys...lets all hit the "post" button at the same time
Old Aug 14, 2003 | 06:54 AM
01ITR#700's Avatar
I'll be testing the limits of the stock sleeves and rods here in a few days. I made 282 on a 100% stock internal ITR motor w/ turbo. Now I'm running 9.0:1 Arias Pistons, stock rods, bigger turbo, and fully tuned with the Hondata S200 as well.
Mark
Old Aug 14, 2003 | 07:31 AM
blumeany's Avatar
Default Re: How much HP is Type R bottom end good for? (01ITR#700)
01ITR#700 what size turbo are you planning on running? I am running T3 60-1.
Briang3a3
Jan 17, 2008 04:10 PM
iownanrsx
15
Mar 27, 2007 11:10 AM
QwkD16
Dec 5, 2005 02:39 PM
speedy108
Jan 8, 2003 07:52 PM
itr1236
Mar 10, 2002 05:18 PM
