!@#$%^ Alternator bolt!
Old Aug 14, 2003 | 05:44 AM
Jet Black's Avatar
Default !@#$%^ Alternator bolt!
yes....the dreaded alternator bolt needs to be removed....that POS one that ALLLWAYS seizes (lower alternator bolt)
Does anyone have tricks? I've tried quenching it....but it didnt help....and I lit the belt on fire.....there isnt enough clearance to get an impact in there....I'm considering chopping the bolt head off.
Old Aug 14, 2003 | 07:27 AM
keithv's Avatar
Default Re: !@#$%^ Alternator bolt! (Jet Black)
breaker bars are your friend. also you can try the hooking 2 wrenches together trick...
Old Aug 14, 2003 | 09:17 AM
Jet Black's Avatar
Default Re: !@#$%^ Alternator bolt! (keithv)
Well...here is the problem:
There isnt enough clearance to get at the bolt from the top....the strut tower is too close to allow a rachet & socket in....so I have to get at it from the bottom....longest arm I can fit is about 2 feet long....even pushing will all my weight against it ...it wont budge
Old Aug 14, 2003 | 10:09 AM
keithv's Avatar
slip a bar over the end of a breaker bar and try that...
and see if you can lay on your stomach and push on the bar that way...you might get a little more leverage...
Old Aug 14, 2003 | 10:54 AM
Jet Black's Avatar
Been there done that
Thats what I was dooing yesterday....I think dynamite should be part of all tool sets from now on. I think I'm just gonna cut the bolt head off with a grinder
Old Aug 14, 2003 | 11:39 AM
Jet Black's Avatar
Common guys
Old Aug 9, 2005 | 07:15 AM
Jet Black's Avatar
Ent up cutting the head off with a grinder and then using a center punch combined with a sledge hammer to push the bolt out.
Old Aug 9, 2005 | 07:54 AM
DieMaster's Avatar
Needs to be About 20% Cooler
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keithv &raquo;</TD></TR><TR><TD CLASS="quote">breaker bars are your friend. also you can try the hooking 2 wrenches together trick...</TD></TR></TABLE>
can someone show me how to do that? i've heard ov it but can never get them locked together.
fslim
Aug 6, 2015 06:18 PM
joevincett
10
Aug 11, 2008 06:24 AM
Xuelor5
Mar 9, 2008 05:09 PM
blaze_125
Sep 24, 2007 06:14 AM
Westrock2000
Jan 4, 2004 08:06 PM
