HELP...CAN YOU GET 200WHP FROM A STOCK ITR
Old Aug 13, 2003 | 10:02 PM
yellowredR's Avatar
Default HELP...CAN YOU GET 200WHP FROM A STOCK ITR
Hi Guys I just got my hands on a STOCK 98 ITR...I have been reading up on this but still need as much help as I can get so ALL information welcome... Can you get 200whp out of a stock ITR motor without NOS/BOOST or going into the head or block!!! IF not what is the smartest & safest way to make MAX POWER with an ITR without re-building the motor????? PLEASE IM me with good details THANK YOU!!!
Old Aug 13, 2003 | 10:13 PM
98itR484's Avatar
Default Re: HELP...CAN YOU GET 200WHP FROM A STOCK ITR (yellowredR)
how many places are you gonna post this???
Old Aug 13, 2003 | 10:25 PM
Pacman
Guest
Posts: n/a
Default Re: HELP...CAN YOU GET 200WHP FROM A STOCK ITR (PacMan ITR)
yes, you can
Old Aug 13, 2003 | 10:37 PM
f@sth@tch89's Avatar
What is your definition of stock? what r the stock whp for an ITR? once u change cams or pistons, or chip the ecu...it isnt stock anymore. So IMO i would say no based on my view of "stock". if u change pistons, cams, chip ecu, manifold(i/E) it aint stock anymore. Do u mean "stock" bottom end?
Old Aug 13, 2003 | 11:13 PM
98itR484's Avatar
Default Re: HELP...CAN YOU GET 200WHP FROM A STOCK ITR (fasthatch89)
#1 search is your friend
#2: it will be VERY HARD if not impossible to get 200whp out of a stock ITR motor w/out cams at the very least.
the only thing that will get you anywhere near 200whp is a SMSP/Hytech header a 2.5 inch exhaust intake, and cam gears with TUNING. Chances are you wont see 200whp but you will get close..
GeorgeKnighton got 191whp i believe w/ a SMS header cam gears and tuning
I myself had 187 whp w/ just a SMS header no tuning or cam gears.
Old Aug 13, 2003 | 11:25 PM
allmtr's Avatar
with a bit of head work and good tuning... yes
i just bearly broke 200whp with a 12:1 CR LS/vtec on 91 oct and ITR cams. 204 to be exact...
Old Aug 14, 2003 | 06:49 AM
GreenR's Avatar
Well if you aren't already getting 200 whp from you r stock R, then the answer is no, or else it wouldn't be stock now would it. Now you can get it with minimum mods like
Skunk2 stage 1 cams
Hondata
Comptech header or smsp header or TODA header
Intake and Exhaust
Old Aug 14, 2003 | 07:00 AM
AussieK24's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowredR &raquo;</TD></TR><TR><TD CLASS="quote">Hi Guys I just got my hands on a STOCK 98 ITR...I have been reading up on this but still need as much help as I can get so ALL information welcome... Can you get 200whp out of a stock ITR motor without NOS/BOOST or going into the head or block!!! IF not what is the smartest & safest way to make MAX POWER with an ITR without re-building the motor????? PLEASE IM me with good details THANK YOU!!!
No you will have to modify it
Old Aug 14, 2003 | 07:16 AM
CHEETAH's Avatar
i've had a couple of ITRs doing about 205-210 @ wheels ... was a while ago but here are some of the mods i remember the owners having:
- toda spec c cams/jun stage 3 cams; cam gears with valvetrain upgrade
- milled itr head 30 thous with *flat* endyn valves; stock itr valves
- stock 2 layer headgasket
- spoon header/toda header/2.5" testpipe with 2.5" exh piping and muffler all custom made
- one variant of my Toda spec C program for OBD1 ecu; apex VAFC
- ctr n1 pulley
- jdm 4.7 final drive
- 97 h22a injectors
prolly a few more mods, but i can;t remember them, but both cars had at least the stuff listed above.
Greg
Old Aug 14, 2003 | 09:19 AM
allmtr's Avatar
Default Re: HELP...CAN YOU GET 200WHP FROM A STOCK ITR (GreenR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenR &raquo;</TD></TR><TR><TD CLASS="quote">Well if you aren't already getting 200 whp from you r stock R, then the answer is no, or else it wouldn't be stock now would it. Now you can get it with minimum mods like
Skunk2 stage 1 cams
Hondata
Intake and Exhaust</TD></TR></TABLE>
stage 1's wont be a big improvement over itr cams...
Old Aug 14, 2003 | 09:36 AM
Charlie Moua's Avatar
Default Re: HELP...CAN YOU GET 200WHP FROM A STOCK ITR (allmtr y0!)
search my friend. I swear I have helped out on 3 post almost identical to this within the last 4 day.
BTW yes you can do it but you will need cams tuning and other basic boltons.
Old Aug 14, 2003 | 09:38 AM
Rob Dizzle's Avatar
Default Re: HELP...CAN YOU GET 200WHP FROM A STOCK ITR (CHEETAH)
greg i think he wanted stock bottom end
my guess for 200whp:
filter on a stick with custom heat shielding
endyn cf intake manifold or a ported and polishsed itr intake manifold
hondata intake manifold gasket
cam gears
smsp header or hytech
good exhuast
hondata S200 with at least 2-3 hours on the dyno for tuning.
you might hit it. but it will take some good luck and you can probably only hit it on a dynojet
Old Aug 14, 2003 | 06:23 PM
b19coupe's Avatar
I just got a 2001 ITR and it already had the JDM 4-1 header and AEM CAI. I threw a set of Skunk2 Stage2 cams (GE camgears) and a Skunk2 valvetrain, some RC 310's, and Hondata. Went to Church Automotive, and he managed to pull 197 hp out of the motor, which is equal about 185-190 whp on a DynoJet. Once I get the SMSP header that I ordered, I think that the motor will be really close to 200 whp.
Block and head are untouched-stock.
Old Aug 14, 2003 | 07:18 PM
743power's Avatar
Default Re: HELP...CAN YOU GET 200WHP FROM A STOCK ITR (b19coupe)
EPgonzalez got like 210 whp. If I remember correctly, he had jdm pistons, mugen headgasket and valvetrain, mugen exhaust and header, mugen ecu and c12. Definitely no cams though.
Old Aug 15, 2003 | 05:38 AM
yellowredR's Avatar
thank you for the good advise.....1 question??? I have never heard of SMSP headers but it looks like the way to go based on everyone's feedback... where can I get more info about SMSP???
Old Aug 15, 2003 | 05:52 AM
b19coupe's Avatar
SMSP (Dave) is a user on this board. You can IM him or e-mail him.
https://honda-tech.com/zerouser...=4028
Old Aug 15, 2003 | 11:23 AM
CHEETAH's Avatar
Default Re: HELP...CAN YOU GET 200WHP FROM A STOCK ITR (Bob-DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob-DC2 &raquo;</TD></TR><TR><TD CLASS="quote">greg i think he wanted stock bottom end
yeah the ones i mentioned were stock itr USDM bottom end. no aftermarket pistons or rods.
greg
Mike K
120
Apr 15, 2017 01:58 AM
lsvtec101
Jan 13, 2009 05:37 PM
Gaylorde
Jul 8, 2005 11:47 AM
akasen8
Jun 28, 2004 07:52 PM
yellowredR
Aug 13, 2003 10:06 PM
