'88 HF OBD I questions.
Old Aug 13, 2003 | 08:10 PM
Attoir's Avatar
Default '88 HF OBD I questions.
Buying an '88 HF w/ OBD I conversion already done. The last engine in it was a D16Z6 that the guy blew up at the track.
He was using an '88 Si computer w/ the Z6, and had some sort of RPM Activated module (MSD I think). What exactly is required to convert the car to OBD I at the computer side of the wiring harness? I'm going to be running an OBD I engine, so I'd like to go ahead and use an OBD I computer, do it right.
Are these the wiring harnesses that HASport and such sells?
Thanks for the help.
Old Aug 13, 2003 | 09:07 PM
NoLimitMotorsport's Avatar
Default Re: '88 HF OBD I questions. (Attoir)
Yes, you will need a harness, and run a few wires. Check out the best buys forum, and a guy by the name of jason should be able to help you out.
Old Aug 14, 2003 | 07:02 AM
REDBARON's Avatar
Default Re: '88 HF OBD I questions. (NoLimitMotorsports)
What's up Attoir.
There is a guy on this board that sells a OBD-0 to OBD-1 harness. Post in the classifieds or in the CRX/Civic forum, and I'm sure you'll find him.
Later
Old Aug 14, 2003 | 07:04 AM
REDBARON's Avatar
Default Re: '88 HF OBD I questions. (REDBARON)
Here's the guy you want to IM, Blown90hatcH. He can hook you up.
Good luck with the new project.
Oh, and watch out for those church vans they're maniacs.
Old Aug 14, 2003 | 01:37 PM
RuthlessEF-9's Avatar
yeah jasons a good guy been grabbing jumper harnesses from him for a while now and no complaints from me or my friends with it
Old Aug 15, 2003 | 06:00 PM
spooned out's Avatar
why does everyone want to do OBD-0 to OBD-1? and how much work is it if you have a B16a 1st gen with a PR-3 ecu?
gutted-dx
Aug 15, 2005 01:50 PM
schroddam
Jul 15, 2005 10:29 AM
Vizzion
11
May 9, 2005 09:04 PM
Bigjussin
Jan 15, 2004 04:38 PM
Towsonb16a
Jun 20, 2003 03:45 PM
