preferred piston rings- 11.5 comp daily driven B16
Old Aug 13, 2003 | 07:35 PM
spettinger's Avatar
Default preferred piston rings- 11.5 comp daily driven B16
have some oem honda to go with 25 over ctr pistons, wondering if they are up for the 9500 redline every day. anyone have bad blowby with oem rings? are total seals going to scar the cylinder walls?
Old Aug 13, 2003 | 08:18 PM
johnzm's Avatar
Default Re: preferred piston rings- 11.5 comp daily driven B16 (91hatchattack)
i have blowby with OEM rings, 10,000 miles of 10,000 rpm daily
the motor is from an 90 crx SIR so i have no idea what the original mileage was
Old Aug 16, 2003 | 08:09 AM
B16C's Avatar
Default Re: preferred piston rings- 11.5 comp daily driven B16 (johnzm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnzm &raquo;</TD></TR><TR><TD CLASS="quote">i have blowby with OEM rings, 10,000 miles of 10,000 rpm daily
with a 10,000rpm redline, your lucky that the only that is blowing by is oil and not your rods, pistons or head components.
Old Aug 16, 2003 | 11:09 AM
91tegrals's Avatar
i know people running oem rings with p30s in a ls so im would say oem at least thats wat i plan on using with my pr3s..
Old Aug 16, 2003 | 05:08 PM
johnzm's Avatar
Default Re: preferred piston rings- 11.5 comp daily driven B16 (B16C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16C &raquo;</TD></TR><TR><TD CLASS="quote">
with a 10,000rpm redline, your lucky that the only that is blowing by is oil and not your rods, pistons or head components.</TD></TR></TABLE>
the bottom end is all stock. its got a great R/S. sgt on the fourm hit 11,000rpm with a built b18c that has crappy R/S compared to a b16. so im thinking, why is it that everyone thinks 10,000 rpm is so hard to reach on a stock bottom end b16. so i go out with my mission to hit 10,000 rpm as cheap as possible. and 150 dollars later....
Old Aug 16, 2003 | 05:52 PM
F1Spec's Avatar
oem rings for oem pistons.
Old Aug 16, 2003 | 09:50 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: preferred piston rings- 11.5 comp daily driven B16 (s2geezy)
I doubt there are many people on here even making power that high up. OEM rings.
Old Aug 17, 2003 | 10:28 AM
jrfinfrock's Avatar
the honda compression rings are fine but the oil rings suck. i have a ls with itr pistons with 14000 miloes on motor and it smokes already with a 7200 redline i would go with aftermarket oil rings if i were to do it again
Old Aug 17, 2003 | 03:45 PM
Skeletor's Avatar
the bottom end is all stock. its got a great R/S. sgt on the fourm hit 11,000rpm with a built b18c that has crappy R/S compared to a b16. so im thinking, why is it that everyone thinks 10,000 rpm is so hard to reach on a stock bottom end b16. so i go out with my mission to hit 10,000 rpm as cheap as possible. and 150 dollars later....</TD></TR></TABLE>
I thought the rod bolts begin to strech above 9500. Did you replace those?
Old Aug 17, 2003 | 06:18 PM
johnzm's Avatar
Default Re: preferred piston rings- 11.5 comp daily driven B16 (Skeletor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skeletor &raquo;</TD></TR><TR><TD CLASS="quote">
I thought the rod bolts begin to strech above 9500. Did you replace those?</TD></TR></TABLE>
nope. seems to be no need for replacement. it hasnt grenaded yet and i have been waiting for that day so i can throw in the GSR ive hit 11-12k once. too bad i have no tach that goes that high...
Old Aug 17, 2003 | 06:41 PM
chris@allmotor.net's Avatar
nope. seems to be no need for replacement. it hasnt grenaded yet and i have been waiting for that day so i can throw in the GSR ive hit 11-12k once. too bad i have no tach that goes that high...</TD></TR></TABLE>
oh my god...
Old Aug 18, 2003 | 06:37 PM
B16C's Avatar
that is the illest avatar i've seen in years. is that Frankie? holla back
Old Aug 18, 2003 | 07:29 PM
johnzm's Avatar
Default Re: preferred piston rings- 11.5 comp daily driven B16 (chris@allmotor.net)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chris@allmotor.net &raquo;</TD></TR><TR><TD CLASS="quote">
oh my god...</TD></TR></TABLE>
LOL u guys are so funny. how are u gonna find out how high a stock bottom end is good for if nobody sees???
now since this post has been done everyone who reads it knows that a stock b16 bottom is good for at least 10,000 rpm if not more.
Old Aug 18, 2003 | 11:53 PM
im_poor's Avatar
whats the point of taking it to 10k rpms...you making power there?
Old Aug 18, 2003 | 11:59 PM
snowseeker's Avatar
Default Re: preferred piston rings- 11.5 comp daily driven B16 (im_poor)
It looks cool to the girls? Sounds cool to the guys? Horrible for the motor?
Old Sep 8, 2003 | 09:38 AM
ef-sihatch's Avatar
Default Re: preferred piston rings- 11.5 comp daily driven B16 (snowseeker)
So stoke rings are fine except the oil ring. What brand is the best?
Old Sep 8, 2003 | 12:29 PM
Josh717's Avatar
Default Re: preferred piston rings- 11.5 comp daily driven B16 (ef-sihatch)
he may have some big *** cams, and ive heard of b16s coming over from japan and guys tearing into them and finding that someone built them in japan.
Old Sep 8, 2003 | 03:03 PM
Skeletor's Avatar
that is the illest avatar i've seen in years. is that Frankie? holla back</TD></TR></TABLE>
Koko B. Warrrrreee!!!!
W C L
Oct 17, 2005 01:51 PM
neutron91
17
Aug 28, 2005 07:32 AM
hybridnorth
18
Oct 20, 2004 07:33 PM
quik1
Jun 9, 2004 07:48 PM
PHiZ
Jun 9, 2004 06:01 PM
