Which CP pistons for my car?
Old Aug 13, 2003 | 07:17 PM
Pfieff's Avatar
Default Which CP pistons for my car?
I have a d16y7 and am hoping to get CP pistons, but when looking at their parts list, they only make them for the d16a6 and z6, would either of those work with my y7 block? Thanks,
Pfieff
Old Aug 13, 2003 | 09:31 PM
Skinner's Avatar
Default Re: Which CP pistons for my car? (Pfieffdog)
same bore and stroke in each engine..just different compression ratios
Old Aug 14, 2003 | 03:03 AM
Pfieff's Avatar
So I could use the cp pistons that are made for the a6 or z6?
Modified by Pfieffdog at 9:52 AM 8/16/2003
Old Aug 16, 2003 | 05:52 AM
Pfieff's Avatar
ttt
Old Aug 16, 2003 | 06:52 AM
Skinner's Avatar
Default Re: (Pfieffdog)
all the same except for dome shape for the compression
Old Aug 16, 2003 | 10:20 PM
Pfieff's Avatar
http://www.cppistons.com/PDF%2...6.pdf
Looks like I'll pick up the ones they make for the z6 because of the 9:1 CR unless anyone can steer me in another direction
Old Aug 17, 2003 | 07:02 AM
earl's Avatar
I will ask CP as to how those pistons will work with your motor as far as the compression ratio. You can always mill the head or put a slightly thicker headgasket on to adjust your ratio to get it perfect.
Earl
Old Aug 17, 2003 | 07:43 AM
Pfieff's Avatar
Thanks earl, let me know
turnsignalandy
Aug 11, 2006 11:31 PM
scttydb411
Nov 6, 2004 06:58 AM
Renegade
Mar 2, 2004 12:36 AM
ImportHatch
Aug 12, 2002 04:49 AM
