black clutch fluid? (doesn't stay clean..)
Old Aug 13, 2003 | 04:50 PM
Heinz57's Avatar
Default black clutch fluid? (doesn't stay clean..)
sup fools.
Does anyone know why my clutch fluid from my clutch master cylinder doesn't stay clean? i changed it not so long ago, and its already black.
background info:
-92 civic VX
-changed clutch, master cylinder, slave cylinder, and the upper master cylinder hose to new.
there's a bottom hose to the master cylinder, right? could that be it?
anyone with some info, please help!. thanx.
Old Aug 13, 2003 | 05:07 PM
EG2 SiR's Avatar
Default Re: black clutch fluid? (Heinz57)
bleed, bleed, bleed bleed, bleed, until your sick of it... then bleed bleed bleed some more... till 100% new fluid is introduced into the system...
Old Aug 13, 2003 | 05:20 PM
mph6563's Avatar
Default Re: black clutch fluid? (EG2 SiR)
I just changed my master cylinder, and since I had to drain the reservoir anyway, I cleaned it out. There was a heck of a lot of black gunk resting in the bottom of the reservoir. If I left it in there, I could imagine it would turn the new fluid dark pretty quickly.
Old Aug 13, 2003 | 06:16 PM
Heinz57's Avatar
hey.
when i changed all those parts, i bled my clutch like crazy. i don't think there's any old fluid in the system. but i guess it won't hurt to try again. could there be any other solution? thanx guys.
Old Aug 13, 2003 | 06:45 PM
Shawn C's Avatar
In The Garage
what did you use for clutch fliud? i usually use valvoline synpower synthetic DOT 3-4. stays clear forever, stands up to heat like a ****, and isss good for jOO....
-Shawn
Old Aug 13, 2003 | 08:16 PM
EG2 SiR's Avatar
Default Re: (22lbGS-R)
I agree with usuing the valvoline brake fluid.... that is what I run and it is clear too!
Old Aug 14, 2003 | 06:53 AM
Heinz57's Avatar
Default Re: (EG2 SiR)
i first used regular ol' brake fluid when i first changed my clutch, but then flushed, and changed to valvoline synthetic after changing the master cylinder hose....
i have no clue why its still getting dirty....argh
Old Aug 14, 2003 | 07:00 AM
BROOD's Avatar
Default Re: (Heinz57)
Have you replaced the slave cylinder rubber hose? or is it original?
Old Aug 14, 2003 | 12:10 PM
Heinz57's Avatar
Default Re: (SLPR)
what slave cylinder rubber hose? isn't it just a metal line thats connected to it? you're not talkin' about the rubber boot, right?
Old Aug 14, 2003 | 12:49 PM
EG2 SiR's Avatar
the rubber clutch hose that is attached to the chassis and then to the metal line to the slave.
Old Aug 14, 2003 | 04:55 PM
Heinz57's Avatar
hmm...no, i probabbly didn't. i still can't really picture it right now. i can see the rubber hose that connects the metal line from the master cylinder to the metal line that goes to the slave cylinder...maybe thats it? i'm gonna check it out. i'm pissed that my clutch fluid keeps turnin' black, yo. thanx fo' the info.
Old Aug 15, 2003 | 10:19 AM
Heinz57's Avatar
ok, so i see which rubber hose you guys are talkin' about. i looked it up in my helms, and its just simply called a "clutch hose".
its the hose that joins the two metal lines together from the master cylinder to the slave cylinder.
so i call up three different honda dealers today, to see about how much they go for.
$40!! plus they don't have any in stock.
PLUS: my friend ordered on also, for his 2000 civic dx hatch. guess how much honda wants for it...20 bucks! what the...
anywho..just to update you guys. peace.
Old Aug 15, 2003 | 10:26 AM
EG2 SiR's Avatar
check out inlinefour.com ...... they have steel braided replacements!!!
http://www.inlinefour.com/il4perclutli.html
Old Aug 15, 2003 | 11:17 AM
Heinz57's Avatar
OH MY GOD.
I dont know how to thank you for that valuable information!!!! i'd sooo rather get those than oem rubber..! and its about the same price!!! thank you again.
now, anyone have any reviews on them? hehe..
kupras
Feb 19, 2007 09:30 AM
Problemo
Oct 13, 2005 01:12 PM
Hard2Find
14
Aug 9, 2005 08:32 AM
5GenLude8998
Sep 2, 2003 11:35 AM
PapaRoach736
Mar 1, 2003 07:25 PM
