Brake pad has a surface crack - safe to use?
Old Aug 13, 2003 | 01:35 PM
magic hat #9's Avatar
Default track brake pad has surface crack - safe to use?
this crack has developed on one of my track pads. the crack is on the surface only and does not pass through the pad. is this normal wear? is the pad safe to keep using?
Old Aug 13, 2003 | 01:39 PM
lanceh's Avatar
25 Year Member
Default Re: track brake pad has surface crack - safe to use? (magic hat #9)
i'll let andie give the definitive answer but i showed him pix of pads that looked very similar and he said they were fine to use.
Old Aug 13, 2003 | 01:43 PM
Chris N's Avatar
Default Re: track brake pad has surface crack - safe to use? (lanceh)
What kind of pad is that Aaron?
I have similar cracks, but was told that they were normal.
Old Aug 13, 2003 | 01:45 PM
Big Phat R's Avatar
dun worry bout it
Old Aug 13, 2003 | 02:19 PM
baonest1's Avatar
Default Re: track brake pad has surface crack - safe to use? (Big Phat R)
sorry for the hijack, i didnt want to make another thread. but are these enough pads to run a lap or 2 around lowes motor speedway? or would they not pass me in tech. BTW its for the hyperdrive event, its not a race
front
back
Old Aug 13, 2003 | 02:45 PM
Big Phat R's Avatar
Default Re: track brake pad has surface crack - safe to use? (baonest)
You need a better pic of the front pads Baonest
Old Aug 13, 2003 | 03:08 PM
Bbasso's Avatar
Cracked pads are not good. the material could seperate and then you have none.
Buy another set and be safe.
Old Aug 13, 2003 | 03:41 PM
baonest1's Avatar
Default Re: track brake pad has surface crack - safe to use? (Bbasso)
ill try to get some more pics.. but its not that bright out.
Old Aug 14, 2003 | 12:19 AM
REFLUX's Avatar
[wise man talk]Brake pads aren't cheap but they're one of the cheaper items in the expensive hobby of autoxing/road racing/etc
if you're in doubt, get new pads
don't take the risk, cuz if the risk turns into reality...it's already to late[/wise man talk]
Old Aug 14, 2003 | 09:09 PM
cobalt's Avatar
New User
Already responded in detail to the original e-mail inquiry: pads are fine to use going forward.
For baonest...if you use the brakes hard, then regardless of compound, those pads probably won't last, as brake pads will wear more rapidly as they become thinner. Furthermore, if that is the indicated thickness on your outer pad, then your inner pad is probably 10-15% thinner than the outer pad, due to the design of single-sided piston OE caliper.
-Andie
Old Aug 15, 2003 | 05:16 AM
baonest1's Avatar
Default Re: track brake pad has surface crack - safe to use? (cobalt)
thanx andie for the info. ill be changing them soon for the hyperfest event. probably go with some oem pads for now. im not doing any racing. just a lap around lowes.
jdmsta
Jun 4, 2012 10:42 AM
yoorang
Feb 4, 2007 08:28 PM
JjuuN R
Jan 28, 2004 05:57 AM
mattL
Dec 29, 2002 12:35 PM
Floyd
Feb 20, 2002 08:25 AM
