F23 head H23 block
Old Aug 13, 2003 | 11:16 AM
TS4L's Avatar
Default F23 head H23 block
I have an H23 block that has been re-sleeved and then I used pistons made for an F23 since I was building the bottom end of that, but found out the rod specs I got were wrong and no one makes rods for it. I have seen on here a lot of people say the heads are not interchangeable on h and f series, why is that, the head bolt pattern is the same and the pistons I am using are made to match the head, what are the reasons why it won't match up. I have heard of people doing simalar swaps before but can't find info now that I am trying to do it. Thanks for any help. Thanks, Jason.
Old Aug 13, 2003 | 11:26 AM
carolinaACCORD's Avatar
Default Re: F23 head H23 block (TS4L)
If it'll all match up, then by all means, go for it.
I don't know if it'll work or not.
Old Aug 13, 2003 | 01:29 PM
v4lu3s's Avatar
RTFM
where did you get 1mm overbore f23 pistons?
Old Aug 14, 2003 | 04:46 AM
jweller's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">where did you get 1mm overbore f23 pistons?</TD></TR></TABLE>
yeah. I'd like to know too
Old Aug 16, 2003 | 12:06 AM
KTeller8's Avatar
if you aint bull shooting.. thenn doo it..
someone said you couldnt put a h22 in an accord, untill it happened
someone said why put a Gsr head on an ls motor then boom LSvtec blew up
be smart and make a point
Old Aug 17, 2003 | 06:27 AM
GimpyAccord's Avatar
Default Re: (KTeller8)
ive said a milion times an H head could be put on a F block, hell I've matched them up. the issue is that on the drivers side the H series has an extra set of oil drains outboard:
F:
H:
this problem is easily fixable on the head site, just plug the outboard drain holes, and if you're paranoid dremel some valleys in the head to promote draining. HOWEVER this would be kinda stupid to plug up an H block's outer drain to put an F series head on, IMO. the only H head that interests me on a F block is the H23A1, the vtec heads just need too many rpm's for the f22 to be useful.
Projectludatic
Oct 7, 2010 10:38 PM
92LClude
Aug 9, 2006 09:06 PM
crazykid
Jul 25, 2006 04:55 AM
roycivic92
Jan 28, 2006 09:21 PM
