Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Researching coilovers - what should I be looking for?
Old Aug 13, 2003 | 09:47 AM
ceas's Avatar
Default Researching coilovers - what should I be looking for?
Perhaps one of you can help me with this. I have found a fairly cheep set of full coilovers https://honda-tech.com/zerothread?id=591054 and am going to be calling to get more information on them (quick bit - sold by Hayame, made, by Tokico, under $700 a set). One would think that a shock dyno would be avaiable, and that is what I am trying to get. I am not the best at reading them, and would like to know if there is another site out there that can explain the different nuances in reading them.
ceas..
Old Aug 13, 2003 | 09:49 AM
AdamITR's Avatar
Default Re: Researching coilovers - what should I be looking for? (ceas)
Read this it might help:
http://www.grmotorsports.com/shocks.html
Old Aug 13, 2003 | 11:23 AM
illusion's Avatar
Default Re: Researching coilovers - what should I be looking for? (AdamITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Note than an on-track (or off-track) incident can also cause problems with your shocks. "If the car has been involved in an incident by hitting a wall, guardrail, or another car, then it is best to at least have the shocks looked at," explains Greg Calhoun of Truechoice. "Most times after a hit, the shock will need to be serviced depending on how heavy the hit was." </TD></TR></TABLE>
wow. i hit the divider on the highway and my car sits lopsided. ive had the lca and subframe replaced already but the car still pulls left. shock replacement is next.
.RJ's Avatar
.RJ
Default Re: Researching coilovers - what should I be looking for? (illusion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illusion &raquo;</TD></TR><TR><TD CLASS="quote">
wow. i hit the divider on the highway and my car sits lopsided. ive had the lca and subframe replaced already but the car still pulls left. shock replacement is next.</TD></TR></TABLE>
Upper control arm / bracket
Old Aug 13, 2003 | 12:17 PM
RAB's Avatar
RAB
Default Re: Researching coilovers - what should I be looking for? (.RJ)
good read thanks
Old Aug 13, 2003 | 12:36 PM
Tyson's Avatar
Default Re: Researching coilovers - what should I be looking for? (RAB)
my thoughts on "full coilovers".
http://www.norcalcrx.org/tyson/coilover.html#07
Old Aug 13, 2003 | 12:58 PM
91SiKen's Avatar
Default Re: Researching coilovers - what should I be looking for? (Tyson)
Ceas, are those Hayame coilovers dampening adjustable at all? If they are just height adjustable, I don't think they would be worth it, even at $650.
Tyson, you have the Skunk spring rates reversed in your coilover write up. Skunk actually sells rear stiff setups believe it or not. My personal experience with them has not been great though, so this isn't really a big selling point.
Tyson's Avatar
Default Re: Researching coilovers - what should I be looking for? (91-Si-Ken)
front and rear are interchangeable....
Old Aug 13, 2003 | 01:01 PM
91SiKen's Avatar
Um, not on mine, since they are 8" in front and 6" in rear. I personally wouldn't want to run 436 lb 6" springs in front! Maybe this has changed in the last 2-3 years. Hopefully
Old Aug 13, 2003 | 01:03 PM
Tyson's Avatar
news to me. what car.
Old Aug 14, 2003 | 05:01 AM
ceas's Avatar
Blah, you were right - no dampner adjustments...
ceas..
Old Aug 14, 2003 | 05:19 AM
91SiKen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">news to me. what car.</TD></TR></TABLE>
91 Civic, but the kit was purchased 3 years ago...
Kurly
Jul 19, 2019 06:59 AM
SubSero
Aug 11, 2017 03:17 AM
ekmane
Suspension & Brakes
10
Feb 27, 2013 08:30 PM
euromk1s
Honda Civic (2001 - 2005)
26
Aug 29, 2006 10:36 AM
trickmaster505
Feb 2, 2005 02:37 PM
