Del Sol Gauges question ?? 911 plz
Old Aug 13, 2003 | 07:56 AM
AdamQ3B85's Avatar
Default Del Sol Gauges question ?? 911 plz
Are the gauges on the dohc vtec Sol the same as the sohc vtec Sol, if not what's the difference...
Thanks guys.
Old Aug 13, 2003 | 08:08 AM
AdamQ3B85's Avatar
Default Re: Del Sol Gauges question ?? 911 plz (AdamQ3B85)
c-mon plz somebody help, i have an auction that's ending in an hour. i need to know..
thanks guys
Old Aug 13, 2003 | 08:14 AM
khoalie's Avatar
know for sure that the resline is different but other than that im not sure
Old Aug 13, 2003 | 08:50 AM
mph6563's Avatar
Default Re: Del Sol Gauges question ?? 911 plz (khoalie)
Just the redline, AFAIK. Redline for the Si (SOHC VTEC) is 7,200 and redline for the VTEC (DOHC VTEC) is 8,000.
If the cluster has an A/T gear indicator, it's an Si. The VTEC only came with M/T.
Old Aug 13, 2003 | 09:27 AM
phantom_sol's Avatar
ITS NOT ONLY THE REDLINE. its also the tach itself. the numbers are all off cause the vtec revs higher. it also has an extra light at the bottom. for abs?
but if you are plugging it in into your current harness it should work. with proper calibration
Old Aug 13, 2003 | 01:17 PM
stevecockrill's Avatar
Default Re: (phantom_sol)
phantom_sol is right, the scale on the tach is different for del Sol VTEC and del Sol Si models, as well as the redline being different. You'll need to make sure the calibration is correct.
The extra light is for the low fuel warning light on 95+ models.
Steve
Old Aug 13, 2003 | 05:20 PM
AdamQ3B85's Avatar
Default Re: (stevecockrill)
thanks
Old Aug 13, 2003 | 06:17 PM
sk8rmike's Avatar
Default Re: (AdamQ3B85)
isnt there an ABS light for those sols that did come w/ ABS? i know all VTECs came w/ ABS, and some SI's did....right?
Old Aug 13, 2003 | 06:23 PM
delslow94's Avatar
Default Re: (sk8rmike)
my dohc doesnt have abs it depends on the year and what the origional purchaser bought as options.
Old Aug 13, 2003 | 06:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sk8rmike &raquo;</TD></TR><TR><TD CLASS="quote">isnt there an ABS light for those sols that did come w/ ABS? i know all VTECs came w/ ABS, and some SI's did....right?</TD></TR></TABLE>
Yeah, it could be the ABS light, but not all VTEC models had ABS as noted above......
Steve
ulieq
Oct 8, 2010 03:21 PM
EFMAN
Apr 5, 2005 11:52 AM
Integra_Boi
May 8, 2004 07:26 AM
816d16
16
Feb 19, 2003 08:19 PM
Sterling
12
Jul 17, 2002 06:12 AM
