hatchback dash into a crx?????
i was wondering if anyone here has or knows anyone who has put a 88-91 dash out of a hatchback and put it into a 88-91 crx??? is it alot of work??? i wanted to do this so i can use a 94 and up integra center console and arm rest.. so if anyone has any info or a diagram that could help it would be nice.... thanks........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quiambao1180 »</TD></TR><TR><TD CLASS="quote">i was wondering if anyone here has or knows anyone who has put a 88-91 dash out of a hatchback and put it into a 88-91 crx??? is it alot of work??? i wanted to do this so i can use a 94 and up integra center console and arm rest.. so if anyone has any info or a diagram that could help it would be nice.... thanks........</TD></TR></TABLE>
Well as much as it will fit but mostly people put the CRX dash into the Civic and it bolts right in, However I dont think that the reason your putting it in will work I think that the CRX has less room to put the center console in there and it would be too long for the CRX. Why not try to custom a console to fit into the CRX?? That seems like a lot less work than swapping dashes then trying to figure out who you will make it fit??
Hey guys it can be done. A few years ago an IASCA competitor Scott Harris
( MTX Thunderforce Comp Team ) did this..to create a better sound pathway
for his kick mounted components. He had to cut a few unused brakets on it
to get it to mount but it fit perfectly. Now it all depends on your ultimate
goals...good luck.
goals...good luck.
pinks11
Nov 1, 2007 02:05 PM
4gencivicef9
Mar 26, 2006 05:34 PM
Dorifto13B-T
Nov 23, 2003 07:59 PM
pdiddyparsons
Feb 21, 2003 03:00 PM
